Author Topic: GTR 1000 Carburettor  (Read 23583 times)
Offline LT South Africa
Re: GTR 1000 Carburettor
« Reply #80 on: May 12, 2017, 01:28:55 PM »
Hi guys. That was measured with a school ruler. Probably not very accurate.  I will strip the carbs off the bike again towards the end of the month and see if I can measure it with something more reliable. For now, she is riding okay. I easily get 7000rpm. Although I only ride at about 5000 rpm to work and back. At the start of throttle she has a slight delay which feels like it's flooding, but I'm thinking this could be as a result of the carbs not being synched.
« Reply #81 on: May 12, 2017, 01:30:24 PM »
For once, when riding in 6 I can twist the throttle without gearing down and she accelerates okay.
« Reply #82 on: May 20, 2017, 04:18:10 AM »
I took the carbs off again and measured with a reliable measuring tape. Outside to outside I get 32mm spot on.
« Reply #83 on: May 20, 2017, 07:53:37 AM »
You need to measure inside to inside.
Your inside to inside appears to measure 30... (not 32)
« Reply #84 on: May 20, 2017, 08:50:49 AM »
Oh dear...... The inside to inside is 30mm
« Reply #85 on: May 20, 2017, 02:40:17 PM »
A Connie has a 32 mm carb.
     I.D. is 32 mm (1.260').  O.D. is approx. 38 mm (1.490")
Your Carbs;
          I.D. is 30 mm .   O.D. is approx. 36 mm
With this knowledge, I think rejetting with Connie Jetts might help, but doubtful it would be ideal.
MOB / Steve might be able to suggest jets that would help, but would be best to get correct size carbs and an airbox.
For now, I think you might just raise the needles by placing tiny washers under the jets) and see what happens.
Might fatten it up enough to help, and costs nothing.
« Reply #86 on: May 20, 2017, 10:42:50 PM »
Thanx Ted. Seeing as this might be the last of the Connie's here in South Africa I am going to get her back to original. I'm very proud of this bike. Many guys with modern tourers stop and give her a look over. But, for now it's my only transport. I have sent a few email enquiries to cost the exercise of getting carbs and airbox to me from the US. I should have an answer by Monday. In the mean time. I will raise the slide needles and see how this gives me better effect. At the moment I can easily ride to 7000 rpm. The power is there. Although I only cruise at about 5000 which is already 20kph over our legal speed limit. It's just that little delay on pull off from traffic lights etc which is very annoying.
