It'll fit. Just make sure you read the install instructions (paragraph 2. Note). Its the same for all years. Basically says to remove the plastic trim (called the 'Guard Rail Cover') off the bike (sits under the seat). It is just two screws. Also, may have to use a couple washers as spacers between the seat and the rear seat catch.
