Author Topic: Bike is dead, Jim!  (Read 13822 times)
Offline PlaynInPeoria
Re: Bike is dead, Jim!
« Reply #20 on: November 20, 2018, 06:00:06 AM »
I have heard of so many ground issues.  My bike has never done that thankfully.  But it sounds like it wouldn't hurt to proactively check the grounds.  Next time I do maintenance on my bike, I'd like to clean them.  How many grounds are there and where are they?
Thanks
« Reply #21 on: November 20, 2018, 03:42:20 PM »
Thanks
the two main points are the place the 2 ground wires attach to just in front of the battery, remove those 2 bolts, and scrub the aluminum on the frame with sandpaper, and wipe it down clean with solvent, also clean both the ring lugs on the cable ends that contact the frame, when bolted back on...same manner... the battery connection/wire lug/terminal also requires the same treatment.
(don't worry about the extra red and black wires I show in the below photo, those run to my remotely mounted aux fuse block)
« Reply #22 on: November 20, 2018, 03:54:51 PM »
... and coat the entire connection liberally with dielectric grease to eliminate (OK, delay) corrosion.
I actually coat all of the pieces with grease before I even start assembling them, which is messy, yes, but ensures a thorough application of grease.
This post brought to you by Slippy Fingers Connie.
Offline Poseidon
« Reply #23 on: November 20, 2018, 04:53:21 PM »
Dielectric grease can cause connection issues. It should be applied to the connection after it is tightened down. With automotive electrical connectors, it is recommended to apply to the boot in order to help seal the connection, but avoid the connections themselves. I’ve seen a lot of connection issues on ATVs when guys use too much dielectric grease on the connections when trying to water proof their bikes. Thin coating probably will not cause any problems but if you get carried away with it, it definitely can!
2017 Concours 14
2016 Victory Magnum
2013 M109R
« Reply #24 on: November 20, 2018, 05:14:15 PM »
I agree.  "Dielectric" means that it is an insulator- it blocks conductivity of electricity.  My understanding is that it should be applied AFTER connection, to the outside, and this prevents moisture and oxygen from getting into the connection.  The corrosion caused by moisture and oxygen is what causes the connection to become unreliable over time.
« Reply #25 on: November 20, 2018, 06:20:51 PM »
as the 2 prior posts note, and I have always preached on, Dielectric grease is an insulator, and subsequently should not be applied to the actual current carrying metal surfaces being clamped together... it can be used to 'seal' the connection as assembled clean and dry, when used as an external only coating, but then again anything applied, like clear spray paint, will do the same.
Having worked in the Power Quality industry for 20 years, the only thing that can be applied to the actual current carrying surfaces being clamped (like copper bus bars, and cable terminations as such) is this stuff... NO-OX-ID
https://www.sanchem.com/electrical-contact-lubricant.html
it is the industry standard, we used it for everything that was exposed to humid and corrosive environments, and it is NOT an insulator... I always suggest having a tube, in your stash, for bike work. A little lasts a lifetime.
Offline MtnRider
« Reply #26 on: November 20, 2018, 07:52:22 PM »
« Reply #27 on: November 20, 2018, 10:24:38 PM »
Loctite Dielectric Grease: http://tds.henkel.com/tds5/Studio/ShowPDF/LB%208423-EN?pid=LB%208423&format=MTR&subformat=REAC&language=EN&plant=WERCS
Directions for use:
2. For connectors and battery terminals
  • Make sure ignition system is off.
  • Clean surfaces with appropriate cleaner such as Loctite® Pro Strength Parts Cleaner or Loctite® Battery Cleaner.
  • Coat both parts with grease.
  • Reassemble.
Here's a test, although I can't get the vid to play within this post:
! No longer available
« Reply #28 on: November 21, 2018, 12:54:19 AM »
There is no question that many (if not most) people use it that way, but, nonetheless, dielectric grease is an insulator that inhibits or stops electrical flow.   The reason it works that way at all (coating all surfaces) is because the clamping force of the connection is typically high enough to push the grease out of the way once the connection is tightened, allowing metal-to-metal contact (and, thus, electric flow).  And in most cases, it probably does work that way.  However, I am not sure that will always work as expected.... especially if the current on that particular connection is (or was) never high.  I suppose, theoretically, if the connection wasn't tight enough to push the grease out of the way, it might not have been good enough to allow electric flow in the first place.  So the questions are: can one count on that force to work, and work great over time, and work well at all currents, and does the possibility of current inhibition outweigh the positive of having an even better seal against corrosion?  Hmm...
« Reply #29 on: November 21, 2018, 02:19:38 AM »
...  So the questions are: can one count on that force to work, and work great over time, and work well at all currents, and does the possibility of current inhibition outweigh the positive of having an even better seal against corrosion?  Hmm...
Well, Loctite didn't put their directions in this order:
3. Reassemble.
4. Coat both parts with grease.
If the connection loosens, is air more likely to conduct electricity than grease? Nah. Probably about the same: Nil.
Offline bob h
« Reply #30 on: November 21, 2018, 06:40:39 AM »
The sequence of operations in the Loctite instructions is the best way to insure all surfaces are coated with dielectric grease. There are no solids in the stuff, it's just pushed out of all the spots where the two surfaces actually touch.
I suspect many confuse dielectric grease with heat sink grease.  Many formulations of heat sink grease have insulating solids in it, and will prevent good electrical contact.
« Last Edit: November 21, 2018, 09:54:10 AM by bob h »
Offline jwh20
« Reply #31 on: November 21, 2018, 09:20:01 AM »
I suspect many confuse dielectric grease with heat sink grease.  Heat sink grease does have insulating solids in it, and will prevent good electrical contact.
Good point about dielectric grease and it's purpose.  Some confused individuals have the mistaken belief that because it's "dielectric" (i.e. an insulator) that it's not suitable for battery connections.  In fact this indicates that those people have a misunderstanding about how electrical connections work and what happens to dielectric grease when used between conductors as suggested in this thread.
1) The grease itself is not conductive and therefore it does not enhance the electrical connectivity of the junction directly.
2) The mating surfaces of the terminals, while appearing to be smooth, are anything but from a microscopic viewpoint so in reality only the highest points of the "landscape" actually touch.
3) The "valleys" where nothing touches are the areas of concern since these often allow contaminants to enter and corrosion to build up.  As with so many materials, an oxide or sulfate of the base material (in this case copper and/or lead) is many times larger than the material itself and so the oxidation can actually generate enough force as it forms to push the contacting points apart and allow even more non-conducting corrosion to form.
4) The dielectric grease fills these "valleys" or voids and inhibits the formation of corrosion both between the two surfaces and around the edges so that the contacting points are much more stable over time.
So, in spite of "common" sense (which is anything but common in my experience), which says that putting a non-conductive coating on electrical connections is a bad thing, in fact, it's a good thing and creates a better and more reliable connection.
« Reply #32 on: November 21, 2018, 10:03:10 AM »
Good read. Easy as pie.
Your post count is 314.
« Reply #33 on: November 21, 2018, 11:09:05 AM »
Directions for use:
  • Reassemble.
Plays for me when I click on the link.  Using Chrome?
« Reply #34 on: November 21, 2018, 11:26:04 AM »
Ahh, thanks, these places I know of.  My fear is that there were others that I was missing.
Thank you, MOB
Side note: I think I have 2 additional connector on the positive side, my heated gear/battery tender and power to a relay that runs my dual horns.   I had 3 at one point when I was powering my HID, long since removed since I went to LED.  There is not much room to work behind that battery cover.
« Reply #35 on: November 21, 2018, 11:42:31 AM »
Chrome and Firefox. I can click the link fine, but don't see the actual video appearing my post as I see sometimes.
« Reply #36 on: November 21, 2018, 11:45:01 AM »
Chrome has issues with this site as far as vids go.
« Reply #37 on: November 21, 2018, 02:04:22 PM »
I suppose if you want to believe what LocTite says, in order to sell a product it makes, for a purpose that it truly misrepresents the real benefit, that's fine with me.
from the Loctite data sheet;
"LOCTITE®
LB 8423 is a silicone dielectric compound that
facilitates and improves tune-ups. The compound prevents
voltage leakage around any electrical connector thereby
insuring a strong spark in high energy ignition systems. It is
also an excellent lubricant on rubber, plastic and ceramic
surfaces, and it also has good high temperature properties,
thus preventing fusing of spark plug boots to the spark plug
itself. Typical applications include spark plug boots, distributor
cap nipples,
battery terminals, ignition coil connectors, and
trailer electrical connectors. This product is typically used in
applications with an operating range of -55 °C to 204 °C."
TYPICAL PROPERTIES OF CURED MATERIAL
Electrical Properties:
Dielectric Breakdown Strength,
IEC 60243-1,       kV/mm                   19.8
Dielectric Constant / Dissipation Factor, IEC 60250:   1kHz 3.0 / 0.007
Volume Resistivity, IEC 60093, Ω·cm 2.6×1015
it does not carry current, it is a strongly resistive coating.
they add battery terminals just to increase sales....
As I noted, having worked decades in power quality products, that carry current up to and over 4000 amps, and MUST be reliable to not fail, due to a connection that has been compromised which could bring down infrastructure of major cities, utilities, or government security, I suggest you actually read about the product I linked to....
if they were simply into only selling a product, they would have done what LocTite did...
which is to name 2 other products they sell, to clean the contact surfaces prior to making the connection... but as an industry provider they don't... because they know how to make a reliable connection... and explain it with the step LocTite seems to have forgotten, the part about the cleaning... and the correct means of cleaning....
from the SanChem site....
How to Apply Conductive Grease to Battery Terminals:
*Disconnect the connector from the terminal. When taking the battery out first disconnect the negative terminal (-), then disconnect the positive (+).
*Degrease the terminal post.
*Neutralize the area – this is normally done with baking soda & water (1 lb/ 1 gal.)
*Use a toothpick size steel wire brush to buff the face of the terminal post until the face is bright lead.
*Next, apply a light coating of NO-OX-ID A-Special to all four faces of the terminal post.
*Reattach the cables to the battery. When reattaching the battery, first connect the positive (+) connection then reattach the negative terminal (-).
use whatever you want, in any manner you want to use it in....  use Vaseline, it probably works as good, when applied like that LocTite product, for what that's worth.
I do know about reliable electrical connections tho, and prevention of degradation to them. I wish I could show you I.R. scans of various connections, carrying high amp loads, on products I designed, it would be clear then. Loose bolts, greased connections, etc., Funny part is, I just last month signed off on a patent for a system of I.R. ports I designed;(windows applied to the external walls of large switchgear enclosures) to allow safe scanning of internal bolted bus bar current carrying connections to see if they are 'getting hot' due to compromised clamping forces on bolts over time, from thermal cycling.
Even tho I haven't slept at a Holiday Inn Express for a while, I do know the difference between Dielectric and Electrically Conductive greases. (not to be confused with thermally conductive pastes)...
below shows the "low end" of the ampacity range in current products, based on my designs as Sr. Mech Product Engineer, prior to ABB's recent aquisition of the company I worked for. The larger products, like 4000amp/3 source units I designed, were quite large, 7ft hi x 6 ft dp x 16 ft long... containing about 3/4 ton of copper bus bars, and at least six 350 lb. circuit breakers/molded case switches.  :rotflmao:
loks like this inside...
I designed all of the enclosures, and every mechanical aspect of the components and installation of such, in every one of the products in this brochure;
https://tinyurl.com/y8nwlhux
Loved my job.
https://youtu.be/rZsk_nKJjks
http://youtu.be/rZsk_nKJjks
« Last Edit: November 21, 2018, 03:53:51 PM by MAN OF BLUES »
Offline Poseidon
« Reply #38 on: November 21, 2018, 04:46:17 PM »
3. Reassemble.
Like I had said before, a thin coating probably won’t be an issue, especially like on a battery terminal with a tight connection. It will cause an issue if you use to much on a weather pack connector or similar plug. That is where the ATV and SxS guys always run into problems with dielectric grease. Too much grease and you will drop connections on these. Seen it many times!
2017 Concours 14
2016 Victory Magnum
2013 M109R
« Reply #39 on: November 22, 2018, 10:20:03 PM »
I suppose if you want to believe what LocTite says, in order to sell a product it makes, for a purpose that it truly misrepresents the real benefit ...
I'd suggest you convey this information to Loctite and get them to correct their directions. I would do it myself, but I don't have your credentials and so likely wouldn't be taken seriously.
Let us know how it goes!  :thumbs: :chugbeer:
