Author Topic: Does anyone make a rear stand for the C14??  (Read 12054 times)
Re: Does anyone make a rear stand for the C14??
« Reply #20 on: June 30, 2011, 03:16:31 PM »
This is getting complicated.  Do you really want duals that bad?  Is it going to make that big a difference too you?
Feels like I always seem to want what ever is the hardest to do eh Jim??...  :banghead:
« Reply #21 on: June 30, 2011, 03:21:53 PM »
Does seem that way...so looks and possibly a power increase.  You just can't do any maintenance easily to the rear of the bike.  You could just put on a new tire ( I would go for a longer wearing one) and then sell the bike when it wears out.  That way the new owner can remove your dual exhaust and put a single one back on.
« Reply #22 on: June 30, 2011, 03:32:46 PM »
 ;D ;D ;)
You're funny Jim...  :rotflmao:
« Reply #23 on: June 30, 2011, 03:34:34 PM »
I try...good luck.  You'll need it.  Or........and this is a big Oar, you could just buy the modified center stand and have done with it.  It's only money.
« Reply #24 on: June 30, 2011, 03:40:28 PM »
I think you can still access everything as needed for service with the duals on though, here's some pics.
Offline C1xRider
« Reply #25 on: June 30, 2011, 09:13:39 PM »
Is the Muzzy exhaust the same as ZX14 dual?  If so, the only mod is to extend the lever part so it doesn't hit the bottom of the pipe.  I picked one up off eBay for just that purpose.  Until it's installed, I just added some bumpers to keep the original one from hitting.
« Reply #26 on: June 30, 2011, 09:59:29 PM »
Are you running the dual Muzzys Rob??
Offline C1xRider
« Reply #27 on: July 01, 2011, 08:41:15 AM »
I'm running the ZX14, with TwoBro's slip-ons.
I thought the Muzzy system was compatible with the center stand, same as the ZX14.  The only mod was to extend the lever you step down on out from under the mid-pipe.
