Thanks for the diagram!
thanks for the diagram, we have these in our fsm's. I have examined them well prior to this to preclude the possibility of the led tail lamp being a cause... it isn't. the o/p did in fact disconnect the tail lamps from the system, and it did nothing to remedie the situation.
now explain why the tail.light led's glow, and the license plate light does not... I could interject the voltagebis low enough not to light it, but I believe its more than what you are thinking... my post of the exact codes that would appear, should give some semblence that I am on the pulse of this issue...
the glowing tail marker is a resultant thing... and I do not believe related to the real issue...
this electrical system is both complex in some aspects, and very simple in others, the simple thing is the flyback signals that need to be present, to shut down tertiary systems, coming from ecu's... this is all an orchestrated system, something like this glowing tail light may be a precurser just demonstrating some other pass (thru the ecu) that is being missed.
something is not feeding back thru a loop, telling systems to shut down... it ain't the tail led's doing it....
there is still an undervoltage trigger, that is causing this issue, and also why the throttle sensor is fluttering...and maybe the led thing...
go back, and completely read the whole progression of events.
tuning in on one specific post, and making a diagnosis, and pointing to something totally remote, caused by something clearly significant doesn't do a lot on this.
the codes that popped up are clearly a sign of an undervoltage supply to the bike/ecu/system.
we ran this one down, and put it to bed in one day, when all instructions were followed,.without a bunch of othernstuff being "done" or other people "doing the work" like people supposedly checking battery and saying it is fine...
one of the benefits of the COG membership, is our technical advice, from owners that have a long history on both this bike, and its predecessor...
might want to log in, create an account,.and read a bit...
some of us really do know about this bike..and issues...
http://forum.cog-online.org/index.php?topic=65801.0have a nice day, I'm off.
