Author Topic: how to refuel a C14- Warning Sticker  (Read 8795 times)
Offline Zacharykro6
« on: May 10, 2016, 11:51:55 AM »
Near the fuel cap on my brand new C14 there is a warning not to fill the tank so that there is fuel in the filler neck.
Does this mean that I can not fill the tank to the point that the pump shuts itself off?
I always fill my tank while on the side stand , I had a bad experience where I overfilled a tank while on the center stand and set it on a side stand then fuel came thru the cap seal and covered the tank
Every thing I drive is special and makes me excited just looking at it
Re: how to refuel a C14- Warning Sticker
« Reply #1 on: May 10, 2016, 02:33:19 PM »
I fill until the pump shuts off, then pull it out (easy boys) a little and run it in easy until it is just at the filler neck.
« Reply #2 on: May 10, 2016, 04:31:17 PM »
Here is my own warning. Fill it as far as you want, I'd say within one half inch of the cap
UNLESS
You are on your way to park the bike, and it is hotter than 75 degrees outside and the bike will be sitting in the sun
OR
You are on your way to park the bike, and it is hotter than 90 degrees under the cover where the bike will be parked.
In other words, if you plan to ride it with it full for at least 1/4 of a gallon, you're fine filling it past the neck.
« Reply #3 on: May 10, 2016, 05:59:38 PM »
just a suggestion...
might want to find the right section to post this, and other questions to, especially when asking about a bike that has a complete section noted for answering these things... you might get better responses... most people don't read this section.
« Reply #4 on: May 11, 2016, 05:26:04 AM »
That's for sure.  I'm going to..
http://youtu.be/hdcTmpvDO0I
« Reply #5 on: May 11, 2016, 05:27:10 AM »
UNLESS
OR
« Reply #6 on: May 11, 2016, 05:37:04 AM »
The warning is just there to keep people from spilling out gas when pumping or when it later gets hot and the gas expands.
Offline Hooligan
  • Country: za
  • never assume, get the facts
« Reply #7 on: May 11, 2016, 06:15:14 AM »
Silly question, but does the tank not have an overflow/drainage pipe? ZX12 and ZX14 I previously owned had them. Even the K1200GT B'mer I owned before buying my Connie had it.
I also fill it to almost right up to the cap when riding long distances, but make sure the cap is clear when I'm refuelling and about to park the bike at home.
2012 K1600GT
2009 ZX14
« Reply #8 on: May 11, 2016, 09:55:57 AM »
Yes it does, but then the gas you just paid for gets peed on the ground.
« Reply #9 on: May 11, 2016, 10:20:42 AM »
Kind of like beer!
« Reply #10 on: May 11, 2016, 10:26:47 AM »
Not quite. Gas peed on the ground, never was used for its primary use.
Beer, hopefully was used for its primary use by the time it meets its end.
« Reply #11 on: May 11, 2016, 11:48:14 AM »
Maybe I should just pour my beer on the ground. Would be better for my health, well certainly better for my waist and I could buy cheaper beer as I wouldn't care what it tasted like....   NAAAHHHHH
« Reply #12 on: May 11, 2016, 11:52:21 AM »
You'd still be seen with crappy beer in your hand.
« Reply #13 on: May 11, 2016, 05:25:08 PM »
Yep, which is also not very good for the environment.  Plus it is flammable/corrosive.
« Reply #14 on: May 11, 2016, 05:54:42 PM »
...but it is lighter than water so it won't sink down into your well.
« Reply #15 on: May 11, 2016, 06:21:07 PM »
That is true, but the big problem with gasoline is that it evaporates- that is the pollutant (and also when it becomes especially flammable).
« Reply #16 on: May 11, 2016, 06:26:10 PM »
As it evaporates it also disperses. And as we all learned in grade school ... the solution to pollution is dilution.   8)
« Reply #17 on: May 11, 2016, 06:33:34 PM »
Hmm....
« Reply #18 on: May 12, 2016, 05:00:55 AM »
Maybe you need this POS?    ::)
http://www.mccuff.com/      :rotflmao:
« Reply #19 on: May 12, 2016, 05:18:52 AM »
Well, it's endorsed by Paul Sr., must be good.    Doesn't sound like a bad idea.  Anyone use one of these?
Holy  :censored: t!  Did you see how much these cost?   :yikes: :loco: :nuts:
http://www.amazon.com/McCuff-Industries-Splash-Spill-Motorcycle/dp/B005UGK43M/ref=sr_1_1?ie=UTF8&qid=1463051802&sr=8-1&keywords=mccuff
Are they out of their  :censored: ing minds?
