Author Topic: Where are you saddlebag locks?  (Read 10459 times)
Re: Where are you saddlebag locks?
« Reply #20 on: May 11, 2016, 12:04:34 PM »
« Reply #21 on: May 11, 2016, 12:37:35 PM »
Just curious here, can you take a look and see how the latch mechanism lines up? It would seem unlikely that it would line up perfectly and perhaps be a bit off center front to back (or left to right as you look down at it) if it was on the wrong side unless mama Kaw went to the trouble of designing it that way ...and why would they do that? I'm currently hundreds of miles away from my bike or I'd go check myself...anyway if they are lined up OK then I guess you should leave them that way as a conversation starter.
dammit you guys.... you made me go out to the garage again, pick up a set of calipers, and measure them..... argggggggggg
on my recall fitted bag latches, correctly installed on my '08 bags, the dimension from the bottom of the recess the latch assembly sits in, to the edge of the orange latch, is identical on the front and rear measurment.... so it makes no difference on which latch was installed on which bag, as the orange part on mine is dead center of the whole insert part...
with that said, and no '09 bags to compare with, the actual latch mechanism on my '08 sits 1/4" forward of the centerline between the 2 hanger tabs molded into the bag..... but again, I said the actual mechanisms are mirror image and symmetrical parts... so they changed the actual back shell of the bag for the '09?????
weird.
no matter, my bags are pinned anyways...
« Reply #22 on: May 11, 2016, 05:23:03 PM »
By the way, the Mrs LOVES the grab handles. We started out touring on a VFR with Givi side cases that had handles that she used for security when I got frisky in the twisties. When we switched to the C14 she said hanging on to the OEM rails was bulling her shoulders out of joint. I am surprised other couples have not found this solution.
I would be nervous.  The bag system is designed to support the bags and their contents.  Having a person grab them and throw weight on them while moving might be seriously overloading the mounting system...  It might be fine but then again....
« Reply #23 on: May 11, 2016, 06:15:25 PM »
Thanks for the comment, food for thought.  Mrs lather has good intuition and will let me know if she feels anything is sketchy. The setup was well tested two weeks ago on the Twisted Sisters and several other good hill country twisties, so far so good.
Offline Hooligan
  • Country: za
  • never assume, get the facts
« Reply #24 on: May 11, 2016, 11:05:11 PM »
My wife doesn't grab anything when I get frisky in the twisities, she smacks the back of my helmet instead and I get an earful over the intercom.    :o
That is the exact reason I "misplaced" the intercom system after the first ride. It sounded like she was talking right inside my head....
2012 K1600GT
2009 ZX14
« Reply #25 on: May 12, 2016, 05:19:51 AM »
I don't have an intercom system per se, but I still hear the voices.
« Reply #26 on: May 12, 2016, 05:29:14 AM »
And how do your voices like it when you get frisky in the twisties?
« Reply #27 on: May 12, 2016, 05:37:11 AM »
twisties?  :o I've never heard it called that before...
Offline Hooligan
  • Country: za
« Reply #28 on: May 12, 2016, 07:27:57 AM »
So you like square rear tyres....?
 :stirpot: :stirpot: :rotflmao:
2012 K1600GT
2009 ZX14
« Reply #29 on: May 12, 2016, 07:31:51 AM »
For the most part.  They tend to disagree with each other.
Offline kwakrider
  • Country: za
  • Black- 2009
« Reply #30 on: May 13, 2016, 02:41:41 AM »
But sometimes they do come up with good ideas...well mine do at least!!  ;D
« Reply #31 on: May 16, 2016, 12:48:59 PM »
My wife doesn't grab anything when I get frisky......
Unfortunately for me, I can echo your quote but I have to stop earlier in the sentence.  :(
« Reply #32 on: May 16, 2016, 01:01:24 PM »
IIRC Mrs. lather is pretty svelte, but it could be a valid concern for many.
 I can't believe you two were in Texas and didn't stick around (or rather time your visit) for the nearby T-28.
« Reply #33 on: May 16, 2016, 05:13:02 PM »
Stacie's about 103lbs, I rarely notice she back there. She's still working and had to get back to the grind. We originally planned to do the Wildflower event but she couldn't get that week off. She had to use her first pick to lock in dates for STAR in Vermont!
« Reply #34 on: May 17, 2016, 05:15:45 AM »
My condolences.
