Author Topic: TPMS  (Read 2125 times)
Offline K0rnfl4k35
TPMS
« on: May 07, 2016, 07:39:03 AM »
My front TPMS every once and awhile will just show -- while im riding. It never says low battery and the tire pressure is correct. It does come back sometimes but usually ends up going away. Does anyone know a fix for this or do i have to take it in?
Offline mikeeitup
Re: TPMS
« Reply #1 on: May 07, 2016, 08:37:21 AM »
There is a DIY somewhere on here ya just gotta search but it is pretty complicated. SO with that said call your COMPETENT local dealer (I say this because the first dealer I called had NO effin clue what I was talking about) with your vin and see if they will do a warranty replacement!
Mike
~Mike~
~2012 Black Connie~
Re: TPMS
« Reply #2 on: May 07, 2016, 10:16:37 AM »
Indeed it sounds like an intermittent sensor.... it is turning itself off for some reason and then coming back on, while being used.  As a sealed unit, it really isn't very serviceable, but especially shouldn't try to mess with it if it is under warranty.  This must be pretty rare, since I have not seen a report of it before.  If the battery were low, you would be getting that warning.  It is only normal to see "--" before the first 30 seconds or so of moving after starting from a very long-stop, since the sensor hasn't had time to wake yet using the centrifugal switch.
Offline K0rnfl4k35
Re: TPMS
« Reply #3 on: May 08, 2016, 09:49:32 AM »
I called the dealer and I gonna have to take it in.
