Author Topic: Dual horns?  (Read 2469 times)
sailor_chic
Dual horns?
« on: March 02, 2016, 09:19:35 PM »
Is there a dual horn setup available that will fit a C14? I'm kinda thinking like a plug-n-play type of a thing. Gotta keep it easy!
Re: Dual horns?
« Reply #1 on: March 03, 2016, 03:47:12 AM »
A pair of these might work.... http://www.aerostich.com/fiamm-freeway-blaster-horn.html
No personal experience with them.
Re: Dual horns?
« Reply #2 on: March 03, 2016, 04:03:53 AM »
I have this setup and I like it!(bought mine at a local auto parts store)
It's not Plug-N-Play as most dual or louder aftermarket horn setups aren't.
I used a relay which is activated by the horn wire to supply direct power from the battery.
It's a tight fit to locate them where the factory horn is (that's where mine are located), but it's doable.
I've helped others with the installation of dual horns at wrenching sessions, so if/when you make your decision on which horn(s) you want, find a COG Wrenching Session in your area for assistance with the installation.
Re: Dual horns?
« Reply #3 on: March 03, 2016, 05:44:09 AM »
Possibly these:  http://smile.amazon.com/85114-400Hz-500Hz-112db-Sports/dp/B004FXMGLY/ref=sr_1_3?ie=UTF8&qid=1457008799&sr=8-3&keywords=Piaa+horns
They pull a shade over 5 amps.  Stockers pull less than 3.  Circuit is protected by a 10amp fuse.  Not sure how the horn switch will like it. Up to you on a relay.  Here's a discussion on them from the GTR UK forum.  I'm thinking about getting a set myself and actually install them (for those doubters).
http://www.gtr1400.co.uk/forums/index.php?topic=5337.0
Re: Dual horns?
« Reply #4 on: March 03, 2016, 06:06:13 AM »
Looks like one horn. Is there two in one housing? Seems a bit large.... 8.6 x 6.7 x 2.3 inches
Re: Dual horns?
« Reply #5 on: March 03, 2016, 06:37:26 AM »
Nope.  Two horns..and they can fit where the stocker goes.
