Author Topic: Tank bag with quick release  (Read 9515 times)
Offline dailybibliotaph
« on: January 01, 2016, 05:18:16 PM »
Hey guys. Any thoughts on a tank bag with map window that's easy to put on and release for a 2009 C14- I live in Manhattan and street park most months. Thanks.
The Internet - feeding conspiracies to the uneducated since 1991
Offline Freddy
Re: Tank bag with quick release
« Reply #1 on: January 01, 2016, 06:20:02 PM »
Bagster tank cover and bag.
http://www.bagster.com/tankcover.html
Offline jtk1531
  • Country: my
« Reply #2 on: January 02, 2016, 01:44:06 AM »
if you don't mind the bag covering up your central glove box, how about magnetic tank bags?
i've been using FirstGear - Onyx daily on my bike for about 3-4 years. i use the side strap when i'm off the bike, there's backpack straps hidden under the magnetic flaps too.
easy to put on and take off since it's magnetic.
pretty big map window, expandable to fit a full face helmet.
link: http://firstgear-usa.com/luggage/onyx-expandable-magnetic-tank-bag.html
« Reply #4 on: January 02, 2016, 08:03:12 AM »
Thanks for all the replies. Some great options. I think I'll go with a magnetic solution since it really will be quickest on-off both for fueling and for parking.
jtk1531 - looks perfect for what I'm looking for and the price is right! Thanks!
Offline freebird6
  • In a big country...
« Reply #5 on: January 02, 2016, 09:42:55 PM »
« Last Edit: October 21, 2016, 06:06:12 PM by freebird6 »
2008 Concours
2007 Mean Streak
99 r1100rt
« Reply #6 on: January 03, 2016, 10:04:40 AM »
If you keep your motorcycle tank bag in the garage and you also use your garage as a shop or for various projects occasionally involving files and or hacksaws, then you'll need to fastidiously check the magnets for metal particle pick up. If not, sooner rather than later you will scratch up your bike. Yes lots of magnetic tank bags in use, and lots of scratched tanks as well. Be careful and find a system either to ensure clean magnets or frequent checking.
When metal particles do stick to the magnets, I've found that a thorough air gun blast is about the easiest way to get rid of them. Trying to pick them off or using tape is tedious and usually incomplete. That's 50 percent of why I went with the bags connection quick lock ring, the other 50 percent was to get the bag easily electrified for cell phone, etc. charging using the electrified ring.
« Reply #7 on: January 03, 2016, 10:19:18 AM »
Marty, how well does the bag fit the slope of the tank?
« Reply #8 on: January 03, 2016, 12:46:21 PM »
I think well, but stand by for a photo. YOMV
edit I guess not as well as I remembered. I forgot that I had moved it back (the mount receiver under the bag can be moved across a short range by making new holes) for bar clearance after I installed the AST pull back adapters. It doesn't look so great now.
I also forgot to mention how ugly the mount is when the bag isn't on it. (I've grown used to it.) Those issues aside it's a great bag and it can expand to hold a lot of stuff.
« Last Edit: January 03, 2016, 01:47:09 PM by fartymarty »
Offline Pilgrim
  • '12 Black
« Reply #9 on: January 03, 2016, 12:50:59 PM »
I've got the Cortech Super 2.0 18l magnetic tank bag.  It has some good features and it works for me.
« Reply #10 on: January 03, 2016, 12:52:00 PM »
You mean I have to get out of the Lazyboy to see the pic?
« Reply #11 on: January 03, 2016, 12:55:46 PM »
Pilgrim, that looks good. How close to the bag are the bars at full lock?
Offline Pilgrim
  • '12 Black
« Reply #12 on: January 03, 2016, 01:07:11 PM »
At full lock they touch, just slightly.   But, that doesn't happen very much, only when you're maneuvering to park.
« Reply #13 on: January 03, 2016, 01:37:00 PM »
No, poor choice of words on my part. I had to get out of my LazyBoy to go take the first two photos. I even put my pants on, but I stayed in my slippers.  :thumbs:
http://www.zggtr.org/index.php?topic=20638.msg255789#msg255789
« Reply #14 on: January 03, 2016, 02:50:07 PM »
Thanks Marty. I have the same bar to bag problem. Cortech Dryver set back on it's mounting ring. Honks the horn on a full lock left. As Pilgrim said it's just on walking speed maneuvers. Irritating none the less.
Offline rhhall
  • I'm your huckleberry
« Reply #15 on: January 05, 2016, 01:07:00 PM »
+1 on the Cortech
rick
08 Connie ABS(totaled)
14 Connie
Offline mikeb2411
« Reply #16 on: January 06, 2016, 12:41:57 PM »
My magnetic tank bag has scratched my tank...twice and all because of what Marty described. The bag picked up metal >:( :'(!
Mike
Ojai, CA
2016 Black Triumph Trophy SE
Offline kzz1king
« Reply #17 on: January 06, 2016, 01:00:10 PM »
So far no scratchs. I keep my bag in a large garbage bag when not in use as I do some metal work in the garage. I only use mine about 10 days a summer though.
Wayne
2010 CONCOURS
1974 Z-1
