Author Topic: ECU flashing now available  (Read 169375 times)
Re: ECU flashing now available
« Reply #220 on: May 06, 2016, 06:54:33 AM »
Still haven't heard from AreaP as to if and when I can get a full exhaust delivered.
Offline blue14
« Reply #221 on: May 06, 2016, 07:43:40 AM »
not at all. Steve
It does a little bit in that you get better fuel mileage with eco turned off running Steve's flash.
2010 C14, 2007 ZX14,  2004 KTM 300SXC
Offline PlaynInPeoria
« Reply #222 on: May 10, 2016, 09:53:39 AM »
That's confusing.  I think you get better mileage in ECO mode (or whatever it's called) regardless of whether you are bone stock or have Steve's flash.   I believe Steve just stated that his flash doesn't touch those maps.
Offline EZ
« Reply #223 on: May 10, 2016, 11:03:07 AM »
I think he just means that the bike gets better mileage now (on the flash) than it does in ECO mode. I know it made a big difference on mine. Best I used to see even at cruising speeds for long periods was 39-40mpg. Now I get 42-43 in town. Then again mine is the far superior first Gen with only a GO mode.  ;)
« Reply #224 on: May 10, 2016, 01:51:45 PM »
Mine is getting better gas mileage and I don't have no stinkin eco mode...
Offline tweeter55
  • Ride Hard...Ride Safe
« Reply #225 on: May 10, 2016, 02:49:48 PM »
If it did, would you use it?
I think I know the answer.
« Reply #226 on: May 10, 2016, 04:31:39 PM »
None of use do... but Gen 2's have a FEA [Fuel Economy Assist] mode!!! :)  :P   :deadhorse:    :banghead:   :stirpot:
Offline smokin
« Reply #227 on: May 10, 2016, 09:28:28 PM »
http://gtr1000.yuku.com/reply/50307/Dyno-charts-for-the-1400#reply-50307
http://images.yuku.com/image/jpg/ca116b9a007906189439e9712a9b54ac75be9203_r.jpg
Above a link to  Dyno chart of GTR1400 in Australia with a different Kawasaki exhaust and the flies out. In eco mode it is making more power and torque than in normal mode. Standard unflashed ECU.
SONS OF ARTHRITIS RIDE HARD MEDICATE OFTEN.
« Reply #228 on: May 11, 2016, 04:46:58 AM »
 :thumbs:
Offline Eupher
  • U.S. Army, Retired
« Reply #229 on: May 11, 2016, 06:34:52 AM »
I'll be removing my ECU this weekend and packing it up. (I'll send you a note, Steve, per your instructions.) It'll likely go out next Monday.
My 2012 C14 is relatively new; only 1,400 miles on it. I've got a Muzzy slipon on it, and aside from a few ergo/protective farkles, not otherwise decked out. All the same, in low RPMs, there is a bit of catchiness - not enough to be disturbing, but it's there - that I have to imagine would become more pronounced with more miles.
I'm not blessed with a lot of twisties where I live, but there are a few straights that I figure will be interesting to negotiate. All the same, I'm not an aggressive rider but do appreciate a motor with muscle. Looking forward to this experience.
2012 C14 Arabian Candy Red
2003 Honda 919
1981 Suzuki 650E
1965 Honda S90
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« Reply #230 on: May 11, 2016, 08:43:41 AM »
just in... finally got the full areaP system flash dyno'd. done on the same dyno as all my other runs, and also the same dyno that Daytona mike used for his flies out / pcv runs. Mine squeaks by Mikes, a couple HP here, a couple there. I think this proves that flies out and a PCV isn't the only way to get power from a c-14.
  Here's the chart, I'm having trouble getting it sized to post. important #'s, 160.83 Hp, 102.69 Tq CF-Std, a/f ratio at top 12.9:1 Steve
« Reply #231 on: May 11, 2016, 09:05:33 AM »
Sweet!! Now if only I could get AreaP to sell me an exhaust...
« Reply #232 on: May 11, 2016, 09:32:44 AM »
Have you adjusted your throttle cables?
Offline Throttle 8
« Reply #233 on: May 11, 2016, 09:33:53 AM »
I offered them money. It worked for me! lol! :rotflmao:
2014 C14
2000 ZX12R Ninja
« Reply #234 on: May 11, 2016, 10:19:40 AM »
I also offered them money. Still waiting.  :(
Offline Eupher
« Reply #235 on: May 11, 2016, 11:07:08 AM »
Yes.
2003 Honda 919
1981 Suzuki 650E
1965 Honda S90
« Reply #236 on: May 11, 2016, 05:29:02 PM »
just in... finally got the full areaP system [...]  160.83 Hp, 102.69 Tq CF-Std, a/f ratio at top 12.9:1 Steve
Nice!  About the only thing else to test would be the larger ZX throttle bodies :)
« Reply #237 on: May 11, 2016, 05:57:03 PM »
and dualies...and  :rotflmao:
« Reply #238 on: May 11, 2016, 06:22:59 PM »
and dualies..
Oh, that is true.  I forget that although the full area P is larger header, pipe, and muffler, it isn't is dual system.  However, I don't know if that will ultimately matter.  I suppose it depends :)
Offline Throttle 8
« Reply #239 on: May 11, 2016, 06:36:04 PM »
What did they say the issue was? I found them awesome to deal with, they even got me one with the turndown tip because I didn't care for the new styled one as much. I think they might want to concentrate on making a bunch of full systems, because I have a hunch they are about to get busy. ;D
2014 C14
2000 ZX12R Ninja
