« Reply #139 on: January 06, 2016, 03:24:47 PM »
[throttle tamer] Yep, but I only got it because everyone else was getting it.
The Throttle Tamer is very effective at greatly reducing so-called "throttle snatch". Since the secondary butterflies can limit airflow, it is theoretically possible to simulate what the Throttle Tamer does mechanically but in the ECU. However, if ECU changes do that AND one already has a Throttle Tamer, then the effect would be to
double the taming, which might not be desired...
« Last Edit: January 06, 2016, 04:07:06 PM by maxtog »
Logged
