(My intro thread
http://www.zggtr.org/index.php?topic=20304.0)
Eli hit the 600 mile mark today and the bike is exactly the ride and experience I was looking for. Smooth, quiet, powerful, authoritative (even at < 4000rpm), extremely well built, and just stays out of the way - no drama from the bike at all.
So I changed the oil, filter, and rear lube today which is a PLEASURE on this bike. Not a stray drop of fluid anywhere. The bike only had a touch over three quarts in it from the showroom floor. Since it is a 2011, the OE filter was a Japan/Denso 16097-0004, the old style fiber kind without endcaps. It was totally full of gunk and the can had a lot of junk and metal shavings in it, so I guess the filter and break-in oil did its job but I was relieved to change the oil and get on some 'real' oil.
I went with Mobil1 4T 10w-40 and a Mobil1 M1-110. I put all but 5.5oz of 4qts to get a third of the way above the low level mark when balanced on the tires. On the center stand, the level is midway between the two lower marks. The rear was MasterPro 75w-90 synthetic, which is OReilly house brand.
I decided to start with some protective farkles since I noticed my cool weather pants started scuffing and scratching the tank and side panels... YUCK! So, for starters...
- TechSpec shark skin pad kit for tank, side panels, and panniers
- Cox Racing radiator guard
- Fenda Extenda
- Grab-On foam grip covers (I use on all bikes)
- Heli Bars riser blocks with RAM ball and power socket
- RAM mounts for brake and clutch brackets
Probably go with a Calsci screen in standard width and medium height in the near future to eliminate buffeting and get another inch of height in the full up position, which would be perfect.
Love my new bike and goes great with my ZR7 - a perfect pairing for me.
