Author Topic: Kawasaki C14 OEM top box  (Read 8287 times)
Offline toxxic
« on: June 24, 2011, 06:30:26 PM »
Are any of you running the stock, Kawasaki OEM top box on your 2008 or 2009 C14's?
I am transitioning from a CBR1100XX and have a LARGE Givi/E55 Maxia case, which I would like the option of running. However, I am not certain if the OEM box and its mount will interchange with the Maxia case? (I have also have the opportunity to buy a color matched OEM box and mount.) The Maxia case uses the Givi Monokey or SW-Motech kit.
Additionally, I really like the look of Phil's Farkle rack and thought about buying one, but was a little worried about the disclaimer on his web page saying it would crowd a passenger if used with the Maxia E55 case....
Great forum, thanks for any help or experiences you can share!
Tim
Offline stewart
Re: Kawasaki C14 OEM top box
« Reply #1 on: June 25, 2011, 08:19:27 AM »
I'm using Phils rack and the E55 and I don't know how people could be crowded. Plenty of room for my wife and I.
Stewart
2010 Concours14
COG 9380
« Reply #2 on: June 25, 2011, 09:16:38 AM »
I ride an 09 and have the Kawi 47 trunk with the Admore light kit mounted on Phils rack, great set-up IMO...  :thumbs:
Offline Gsun
« Reply #3 on: June 25, 2011, 10:50:26 AM »
Thanks for the picture. I just bought a Corbin backrest (not picked up yet) in hopes that it would not impede the Kawi trunk. Looks good!
« Reply #4 on: June 25, 2011, 11:03:43 AM »
Yep, if you slide the mount as far back as you can on Phils rack it will just clear the Corbin backrest...
Offline Cold Streak
« Reply #5 on: June 25, 2011, 11:10:57 AM »
I have the OEM top box on my 08.  I am just using the OEM mounting system also.  It works okay, but you need a different key, like all the others I guess.  The only problem I've had is the plastic piece that mounts it to the bike broke after about 15000 miles.  Kawi replaced it under warranty but I made my own replacement that will never break.
Offline toxxic
« Reply #6 on: June 26, 2011, 10:51:12 PM »
Great info, thanks guys! I really appreciate all the pictures.
Looks like the Kawasaki bag might use the same mounting plate as the Givi/Maxia?
« Reply #7 on: June 26, 2011, 11:08:54 PM »
The Kawi trunk is made by Givi, it's just Kawi badged... it's a E470 Givi with a different outer top skin...
http://www.giviusa.com/cases/Monolock-/E470-SIMPLY-III
Offline toxxic
« Reply #8 on: June 27, 2011, 04:37:25 PM »
Excellent, just the answer I was looking for!
