Yes but the vacuum type; what you are talking about is a positive pressure bleeder. And you <could> use that on the reserviors of a C-14 with some adaptation but I would not do that- too much risk of spraying fluid all over the place (Easy Boys! I meant brake fluid!).
Some people claim they can / have / do power bleed from the bottom up (Boys!) but when I have tried to do that, it always made a mess because brake fluid leaks all around the bleeder screw threads, then onto the rotor, axles, the floor, etc.
A relatively inexpensive ($75 from a brand name co., maybe $25 from Harbor Frieght) power vacuum bleeder works well, will remove ALL the air in a C-14's hydraulic systems, and only requires compressed air to operate.
Is there a power bleeder available? (that works on a bike_
I used to have 1 that fit on top of an automotive master cylinder/reservoir.
Worked great!!!!
(But I doubt it would have worked on top of a plastic/remote reservoir).
I guess, (conceivably) you could pump fluid in from the calipers?
