Author Topic: My windshield assembly broke!  (Read 11661 times)
Re: My windshield assembly broke!
« Reply #20 on: September 18, 2015, 06:54:13 PM »
OFFTOPIC: Great! I am glad to hear you actually used it 'cause as I remember, it had a time limit and I was afraid it would just sort of sit around until it expired. Glad to hear you used it and it seems like you like it- win, win!
My bike is a 2012 Gen 2. Right after I had it shipped to Germany.. Cough Cough... and got it out on the autobahn the stock windshield suffered no damage topping out at 170 but then again I didn't have it there for any extended amount of time. I thought the 155 limiter was a regulatory thing? No? Brian's gift certificate for Ghul that I won at least years fall rally took care of my limiter.
Offline KevinRLi
  • I avoid normal people.
« Reply #21 on: September 18, 2015, 10:48:01 PM »
Win.. I won a door prize. Win it was something I wanted. Win it was $100 off so I could explain it to the wife in a way that allowed me to spend the other $275 AND Win because rather than mail it to Ghul I used it as an excuse to ride 3 hours to have him do it live!!! I LIKE WINNING!! LOL.
Yeah I was up at the fall rally with my son riding passenger. This year we are going again but this time he's riding his own 2014 Versys 650 :)
Offline julianm
  • Country: za
« Reply #22 on: September 20, 2015, 12:23:34 PM »
Had a similar problem to the OP. Strong cross wind, single carriageway, doing about 180 kph, 18 wheeler passing in the other direction, heavy turbulence and crack, windscreen flops down.
It’s a 2010 windscreen with slight modifications in that I drilled extra holes to raise it about 2 inches and fitted an MRA spoiler on the top - see pic. It is not a drastic change to the original and it wasn’t even fully up when it happened, so just a bad set of circumstances.
On arriving home, opened it up and found the bracket had broken – see pic - Windscreen bracket with broken piece” (pic courtesy of the Australian forum). I wasn’t so lucky, the broken off piece was long gone together with the Teflon guide.
Priced a replacement but, as all have found, the bracket is not sold separately and only available as a full system at about US $ 700. Not wanting to spend this kind of money decided to find an alternative solution.
Did some searching and found the Australian forum where someone had made an attachment plate with welded stainless steel and reported that this had worked. Not having the facilities to machine and weld stainless, thought about using mild steel angle 75 mm wide and 3 mm thick but with the one side ground down to 5 mm. In order to attach it to the broken bracket, drilled 3 off 5 mm holes through the bracket through the circular sections. (Also drilled a 2 mm hole through the front to strengthen the assembly – more about that later) – see pic “Windscreen bracket repair 2”
Bent the angle iron using a vice, a clamp and 2 pieces of wood to keep the bends true. Found that it needed a cut-out to clear the lip on the guide plate hence the strange shape. To allow the angle to bend it was slotted and welded after the bending- Finished article pic “Windscreen bracket repair 3.
Need to post some more pics so will carry on in the next post.
Offline julianm
  • Country: za
« Reply #23 on: September 20, 2015, 12:58:54 PM »
Repair continued.
In order to strengthen the whole assembly, on the Australian forum they recommended slotting the guide bar and tapping a thread into the new plate. As I again don’t have the facilities to do this, I rather drilled a 2 mm hole right through with the idea of using a 2 mm bolt and nut.
Assembled the set up and used a sharp pencil through the hole to mark where the slot should go.
Cut the slot with a small angle grinder and a worn down thin cutting disc and finished off with a file - see pic “Windscreen bracket repair 4” which is a top view showing the slot and bracket
Having lost the Teflon guide, I had to make this from a Teflon block. Cut the slot with a hacksaw and filed it down to fit. Once completed, drilled the 2 mm hole through the Teflon to accept the screw. “Windscreen bracket repair 5” shows the end view with the Teflon guide.
Windscreen bracket repair 6 shows the finished assembly from underneath.
The OE slot in the Teflon guide is wider than the one I made and I think this is what contributes to the normal movement of the screen. Mine is a snug fit and the windscreen is not affected in the same way behind trucks. The one down side is that with the 2 inch risers I have, the front corners of the fluid reservoirs now touch the screen at full lock.
If the position of my slot in the Teflon had been a bit lower, this would have created the necessary clearance.
However by this stage I didn’t really want to fabricate another block so let it be.
Have also returned the screen to the original mounting holes to reduce the force on the assembly.
Have now covered about 2000 km since the repair and all going well.
So in future in a strong cross winds and seeing approaching trucks , will be tapping off , lowering screen and following Brian’s advice of holding the top to support
« Reply #24 on: September 20, 2015, 01:07:43 PM »
This is making me nervous for when I run with the stock full screen and the MRA X-creen on top.  Perhaps I will try to avoid trucks in such situations.
« Reply #25 on: September 20, 2015, 06:27:55 PM »
Good luck with that.  I just get by them at light speed.
Offline mikeb2411
« Reply #26 on: September 21, 2015, 03:18:23 PM »
I've tried several different windscreens. I've had the Aeroflow large, CeeBailey's Ultra, CalSci large/wide, Vstream, MRA X-creen and the one I currently have on my bike, the tinted CeeBailey's EuroTour.
My favorite windscreen "looks" wise was the Vstream but it wasn't the best at producing clean air.
The tinted EuroTour is nice and produces "clean air" and I like having it on my bike but I still like the MRA best!
All those windscreens were good in their own way but I prefer the smaller screens. The smaller screens aren't quieter than the large screens but the large weren't that much quieter to make that big of a difference IMO and I like that I can lower the smaller screens to let more air in when it's hot. If I need to be warmer in the Winter I'll put my warm gloves on and my heated liner, dickie turtle-neck, fire up the heated grips and seat warmer and I'll be fine!
The MRA X-creen was small and discreet yet produced really clean air. Put the MRA on the Madstad brackets and it was awesome! I loved that windscreen but SOLD IT. I was thinking about the windscreen I could use "year round" and felt the EuroTour would be better but I feel I could have ridden with the MRA year-round and been just fine. Hope you have a good home now :'(.
I had to "thin out" the herd and chose to keep the CeeBailey's but could have easily kept the MRA and may have to purchase another one later on down the road. I will agree that the larger shields can make a person "nervous" in windy conditions or when passing large trucks/tractor trailers (no one should be passed by a large truck unless you're parked on the side of the road)!
Trying to find the best windscreen for me was a pain and cost me some money but at least I know what works for me so it wasn't a complete loss!
Mike
Ojai, CA
2016 Black Triumph Trophy SE
« Reply #27 on: September 21, 2015, 04:51:46 PM »
I gave up trying on the concept of one windscreen for "year round" and now flip between a cut-down gen2 screen + X-creen and a full gen2 screen + X-creen.  Seems to work great, as long as I can pick the correct time twice a year to switch between the two :)
Of course, needs will be dictated by your local weather patterns and your temperature tolerance.  In SE VA it is both freaking hot and pretty darn cold, plus I don't have hardly any tolerance anymore.
Offline mikeb2411
« Reply #28 on: September 21, 2015, 05:07:21 PM »
Of course, needs will be dictated by your local weather patterns and your temperature tolerance.  In SE VA it is both freaking hot and pretty darn cold, plus I don't have hardly and tolerance anymore.
I hear ya'! It's different for everyone depending on where you are. I am in So. Cal. so the MRA could be used all year here. I do live in Ojai, Ca. which can get pretty cold in the mornings during winter...like 20 F...sometimes lower so my mornings can be cold but heated gear fixes that!
Mike
Mike
Ojai, CA
Offline novacon
  • nova scotia t
« Reply #29 on: October 15, 2015, 06:44:28 PM »
Debating between the CB Euro and the V Stream. I'm 5'9 so I think either one would work for me. Would like to see some pics of the V Stream on the Connie if someone could post a couple pics I'd appreciate it. Could be the deciding factor.
tony
2010 connie
Offline mikeb2411
« Reply #30 on: October 15, 2015, 06:51:08 PM »
tony
I will tell you that, IMHO, the V-Stream looks BEST on the Connie! It's a great looking windscreen!
Mike
Ojai, CA
