Mine did this also, when I put new tire on right before Sturgis. I thought something was loose, or wore out, but bike rides, and wares its rear tire ok, also seems to handle fine.... although makes you wonder why there is some slop back their....
Today I removed the rear wheel for tire replacement and when I wiggled the brake side of the swingarm I noticed movement in the A arm pivot points and some up where the swing arm attaches to the frame that I may not have noticed before. It seems solid with wheel mounted and it's been riding fine, tire wear seems normal and this may be something I just didn't notice in previous tire change as I had a helper that did most of the work. I expected it to be solid with no movement. Am I wrong and the bike is right, is the movement normal? I have video I can send to someone if they wish to take a look. Trying to figure out if I need to order more parts. Bike has 26K
Mal, good to hear from you. Back on a C14. Still got the Vic?
The links, wheel axle and pivots combine to make a box structure. When the wheel is removed, each component seems like it has a lot of movement or 'slop' but once the axle is back in the bike and tightened, again it becomes a complete box structure and is very robust. Nothing to worry about and all of these bikes are like this.Brian
Glad I read this. Thanks for answering Brian and thanks for posting Mal - cause I'd be real concerned if I came across this on my own! Can't recall having this situation on any of my previous bikes.
Probably all of your previous bikes had a conventional, welded, stiff (Boys!) swingarm. The C-14 is very unusual in that it has a four- bar rear linkage system; in fact, as far as I know, the only other bike that has it is BMW. Brian
