Author Topic: What'd you do for your Connie today?  (Read 113383 times)
Offline ManWorkinghere
    • Avatar database
Re: What'd you do for your Connie today?
« Reply #280 on: December 06, 2011, 09:06:41 AM »
St. Nick dropped off my birthday present on the 6th today.
A nice Givi 46 topcase for my Kawi C-10.  A nice mounting kit completed the deal.
Thanks, Santa!
Offline michelsmith
  • Country: in
« Reply #281 on: December 06, 2011, 09:40:45 PM »
Awesome bike and nice pics  :)
Offline booger
« Reply #282 on: December 07, 2011, 08:23:47 PM »
Thanks, Santa!
You must have been a good boy  ;)
    • Avatar database
« Reply #283 on: January 08, 2012, 06:08:31 PM »
Got the E128 GIVI mounting kit on the bike last week.  Used the nice weather(40 F) today to see how well the 46L trunk fits on it.  Might put some invisible reflective tape on the bottom of the trunk.  You can see the tape shining off the sidebags when the flash hits it.
(A GIVI E65 backrest pad is now on the trunk too.)
Bigger pics here:
https://picasaweb.google.com/112383979949366115620/ConcoursTrunkOnTheBikeInJanuary2012?authkey=Gv1sRgCKqokrKjg8CylQE#5695425568604136450
Offline jim snyder
« Reply #284 on: January 08, 2012, 06:44:22 PM »
Pulled the carbs this week and sent them to SISF for some "Tweeking". Finished cutting and welding up the new 4 into 1 exhaust system. As soon as the carbs and pipe are back on it will be change the fork oil time. After that greasing the rear drive splines and maybe a manual cam chain tensioner install. When thats done its riding time !!!
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« Reply #285 on: January 08, 2012, 07:22:54 PM »
Jim, the carbs are done, I'll probably ship them tomorrow - steve
Offline jim snyder
« Reply #286 on: January 08, 2012, 09:40:34 PM »
Dang, thats the best service I've ever seen, I didn't even think they had made it to Florida yet.
Offline sas mayhem
« Reply #287 on: January 09, 2012, 08:10:41 AM »
I replaced a broken speedo cable today.
Cheers
Ron
09 Connie
Offline kreaky
  • '98 Connie; '92 750 Nighthawk; '85 VF500F; '96 XR4
« Reply #288 on: January 09, 2012, 01:41:54 PM »
WX is unusually warm for this time of year, 55F, lotsa sunshine. Rolled the Connie out of the garage and washed off all the crud that it collected on the rainy New Year Day ride.
"Once you go over the hill, you pick up speed."
Offline Toxz Qwaste
  • stuff & things
« Reply #289 on: January 09, 2012, 01:55:28 PM »
Dragged my "winterized" bike out of the corner and went for a solo ride up to High Point, NJ and met some like-minded fellows.
Offline buzz
« Reply #290 on: January 14, 2012, 09:31:37 PM »
Busy weekend so far.
Adjusted the valves, put on new brake pads front and rear, tightened head bearings, did the 4" stock spring cut off mod.
Will add Snarfs block off plates before putting the plastic back on.
Buzz
Offline cdc120
« Reply #291 on: January 15, 2012, 05:34:31 PM »
I had a busy weekend as well. I adjusted the valves changed the spark plugs.I got my wheels back from the powder coaters and replaced the bearings. Installed new tires and brakes.I changed all fluids except fork oil. Relocated the coolant over flow.I removed all plastic and sanded it down and primered it with epoxy. Thank goodness it was a three day weekend. Next weekend I'll paint let it cure for a week and then hopefully get everything back together the week after that. Now I just have to decide on which windshield I want and go ahead and order it.
Offline SteveJ.
« Reply #292 on: January 17, 2012, 12:33:32 PM »
I have fresh metal showing on the bottom of my right foot peg from the ride home today. :thumbs:
Despite living in FLA, I have a nice 12 mile country road commute, it has like real corners that aren't intersections.
America's Seaplane City
Offline mr t
« Reply #293 on: January 17, 2012, 06:10:52 PM »
I took it for a nice ride.
      Tom Taylor COG#7173
Offline midnightrider
« Reply #294 on: January 18, 2012, 07:22:08 AM »
I put a shinko 011 verge front tire on and went for a scrub in ride. Wow, I liky the verge.
2004 C10 RIP
voileauciel
« Reply #295 on: March 13, 2012, 06:48:29 PM »
Took her out and rode the bejeezus out of her. Man that felt good!
Offline SteveJ.
« Reply #296 on: March 13, 2012, 07:08:34 PM »
I removed the rest of the mold release on my way home from worksux today on the fresh 110/80zr/18 PR3 I installed at the SiSF Tech Session.
    • Avatar database
« Reply #297 on: March 14, 2012, 02:10:27 PM »
Parked in Motorcycle Parking at work.  Eight nice empty spots waiting to be filled up.
Used the new Givi to hold the helmet instead of using the helmet locks.  Much nicer and faster to get de-geared before heading into the building.
Looking at nice warm ride home not wearing the three layers I used on the way in to work. :)
Offline turbojoe78
« Reply #298 on: March 14, 2012, 05:27:19 PM »
Swapped out the NEW K+L float needle in the #4 carb with the old OEM one from the #1 carb and got her running right for the first good ride this year.
First ride was 2 days ago.
Offline Lodogg2221
« Reply #299 on: March 14, 2012, 06:02:11 PM »
Well, technically, it was two days ago, but I fired her up for the first time since last Fall.
Took a bit of coaxing, but she warmed up and ran great!
Say what?
