Author Topic: What'd you do for your Connie today?  (Read 113376 times)
Offline mr t
Re: What'd you do for your Connie today?
« Reply #360 on: May 08, 2012, 05:48:31 PM »
changed the oil and lubed the suspension ( for starters ) prepping for a 10K TRIP TO Seattle in mid June.
    Tom Taylor COG#7173
Offline buzz
« Reply #361 on: May 09, 2012, 11:00:25 AM »
Installed Snarf's block-off plate kit. really cleaned up the top of the motor.
Buzz
Offline Uded2me
This forum is dead dead dead
« Reply #362 on: May 09, 2012, 01:41:55 PM »
d e a d
« Last Edit: February 21, 2016, 09:19:15 PM by knight_mare »
Offline Jet86
  • California
« Reply #363 on: May 09, 2012, 01:47:05 PM »
What a great trip - I think I have discovered your route...  :)
 :rotflmao: :rotflmao: :chugbeer:
Offline Supatramp
« Reply #364 on: May 09, 2012, 05:22:59 PM »
    Tom Taylor COG#7173
Hey, you wouldn't know of anyone wanting to make some money, lodging two old guys, during Americade, would you?
Offline yoman
« Reply #365 on: May 10, 2012, 07:00:55 PM »
Also finished backs using Duplicolor truck bed liner spray and covered in saten black.
Replaced all clutch/brake fluids.  Pic shown is what I found....
The bags look great. The master cylinder, not so much!
2002 Semi-naked Connie
Offline EmptyG
« Reply #366 on: May 16, 2012, 07:36:52 PM »
1000 words.....
« Reply #367 on: May 20, 2012, 03:47:42 PM »
Moved it out of the garage to get the mower out. 8)
Offline bouts
« Reply #368 on: May 20, 2012, 03:58:15 PM »
Took her for a 270 km ride
Offline turbojoe78
« Reply #369 on: May 20, 2012, 06:35:23 PM »
Cleaned it but good!!  Broke out the Pledge and went at it till I could see myself.   8)
Offline CRocker
« Reply #370 on: May 20, 2012, 08:14:54 PM »
175 mile ride up in the mountains...kind of a shakedown run after recent wrenching by yours truly...water pump still doesn't leak after I worked on it...and the front wheel didn't come off after I did the fork and wheel swap...Whoo hoo!   :) :)
'02 C-10
Offline yoman
« Reply #371 on: May 20, 2012, 08:18:34 PM »
installed fork brace from Murph. Waiting for the "baffel-ectomy" tool to make the rumble, rumble.
Offline SteveJ.
« Reply #372 on: May 21, 2012, 01:51:36 PM »
AAAAAaaaaaaacccckkkkkk!!!!!!!!!!!!
 I just use the mirror iffn I wanna see how handsome I am.  ;) ;) :rotflmao: :rotflmao: :chugbeer:
America's Seaplane City
Offline SteveJ.
« Reply #373 on: May 21, 2012, 01:53:45 PM »
I replaced the actuator cable that runs from cruise servo to the throttle linkage. It was down to one strand. :yikes: :yikes:
Offline kzz1king
« Reply #374 on: May 21, 2012, 04:42:45 PM »
Did not know that could be done. Tough job Steve?
2010 CONCOURS
1974 Z-1
Offline billhook
« Reply #375 on: May 21, 2012, 07:39:01 PM »
Please tell us how this was done and where parts were procured.  I had the same problem and, luckily, had an extra servo and swapped out the whole unit.
Offline kzz1king
« Reply #376 on: May 22, 2012, 10:41:05 AM »
How many miles those units before they frayed? I am going to put a little grease on mine next time tank is off.
Wayne
2010 CONCOURS
1974 Z-1
Offline SteveJ.
« Reply #377 on: May 22, 2012, 06:43:35 PM »
I started a new topic on this, figured there may be some interest.
http://www.zggtr.org/index.php?topic=8871.new#new
Later.
Offline buzz
« Reply #378 on: May 28, 2012, 04:26:02 AM »
Ordered a new set of BT-45V's from MC Superstore
Will get new bearings installed after rims get powder coated gloss black
Offline turbojoe78
« Reply #379 on: May 29, 2012, 03:39:37 PM »
Started the three step process to seal my tank, step one under way.
