Changed front brake pads and fluid, only took an hour spread over 24 hours to get all the bubbles out. The old pads still had decent amount of pad left but I think they were sintered and I like the organic as I would rather change pads than rotors. Changed oil, using havoline 20 - 50W for Texas summers. Washed all the tupperware - noticed a crack in sub-fairing that supports lower farings and bottom fairing. I think RTV should fix it once its dry. Still waiting on new left rider peg and mounting braket - slow motion drop in garage finally finished these off after previous drop cracked them. I am saving up for tip over bars.
Next up - change out rear shock fluid, grease rear suspension and flush coolant and try that Wetter product.
