Author Topic: OEM Oil Filters are made in China, not Japan  (Read 24776 times)
Offline Jay
  • 1979 Kawasaki KZ1000ST
« on: July 15, 2015, 11:44:20 PM »
Maybe many of you already knew this but I found out after buying a couple of filters at a dealership last weekend.
OEM Oil Filter 16097-0004 (made in Japan)  :)
has been replaced by
OEM Oil Filter 16097-0008 (made in China)  :(
And they charged me 33% more!!  :o
OEM Oil Filter 16097-0004 (made in Japan)   http://www.zx-10r.net/forum/f94/new-oem-ol-filters-223122.html
« Last Edit: July 16, 2015, 12:17:18 AM by Jay »
- 2011 Kawasaki Concours 14, Black
- 1979 Kawasaki KZ1000ST (Shaft Drive)
- 1976 Triumph Bonneville 750
Offline Gigantor
Re: OEM Oil Filters are made in China, not Japan
« Reply #1 on: July 16, 2015, 02:47:17 AM »
Good tip, I'm going to stock up on the Japan filters
Offline Gigantor
« Reply #2 on: July 16, 2015, 05:31:11 AM »
The Chinese filter seems to be the same quality
Offline jonathan
« Reply #3 on: July 16, 2015, 08:17:52 AM »
Thanks for the detailed dissection.
Offline philipintexas
    • Phils Farkels
« Reply #4 on: July 16, 2015, 08:20:40 AM »
That seems to be the common method. Manufacture in a cheap labor country then raise prices so the CEO can have a higher salary. NOTHING ever gets improved, just cheaper to make.
Offline Gigantor
« Last Edit: July 21, 2015, 07:31:00 AM by Gigantor »
« Reply #6 on: July 16, 2015, 02:51:50 PM »
+1 wow!
Offline connie14boy
« Reply #7 on: July 16, 2015, 09:38:54 PM »
Just buy the Purolator filter that fits for $3.50 at WallyMart and forget the Chinese crap.
« Reply #8 on: July 16, 2015, 10:06:14 PM »
+1, they've worked in my bike for >107,000 miles.
I use both 14610's and 14612's
Offline Jay
« Reply #9 on: July 16, 2015, 10:20:58 PM »
+2 Wow, wow!
Do you happen to have the same dissection of the 16097-0004 for a side by side comparison?
Offline Jay
« Reply #10 on: July 16, 2015, 10:23:25 PM »
« Reply #11 on: July 16, 2015, 10:49:57 PM »
your sun is accurate. That comparo is insane; that dude needs to go see his kids ;)
Offline Gigantor
« Reply #12 on: July 17, 2015, 05:23:56 AM »
Cross Reference of Kawasaki 16097-0004 to other brands
http://www.oilfilter-crossreference.com/convert/KAWASAKI/16097-0004
Offline Gigantor
« Reply #13 on: July 17, 2015, 05:30:54 AM »
+2 Wow, wow!
http://www.zx-10r.net/forum/f23/oil-filter-16097-0004-vs-16097-0002-a-37012.html
« Reply #14 on: July 17, 2015, 06:18:36 AM »
as far as China, nowadays everything include surgical tools, toothpastes, drugs, and american brand car parts are manufactured in china. its not the real estate a product is manufactured on that determines its quality, its the manufacturing processes and quality control standards that does.
but still, purolater filters have been good to me for >107,000 miles
« Reply #15 on: July 17, 2015, 06:47:19 AM »
Curious as to where the Purolator is made at?
« Reply #16 on: July 17, 2015, 06:51:09 AM »
google says:  Purolator Filters (Purolator Filters LLC) is an American manufacturer of oil and air filters, based in Fayetteville, North Carolina, United States.
Offline Gigantor
« Reply #17 on: July 17, 2015, 08:46:36 AM »
I have not verified this, but you should be using motorcycle specific oil filters part #ML 16817 and ML 16819
Purolator Tech statement:
Don't know if this helps but I called Purolator about the use of PL16410 on a motorcycle because of all good info I had heard about it. The Tech I spoke with said that yes the filter does give superior filtration due to the 3 filtering mediums but that the engineers said the flow is not enough for a motorcycle engine due to the filtration properties. I don't know the flow rates of the Pure One or the OEM so maybe it was all about CYA. Anyway thats the info I got.
« Reply #18 on: July 17, 2015, 03:15:11 PM »
Please don't confuse us with the facts..
« Reply #19 on: July 17, 2015, 03:21:13 PM »
This is absolutely true.  Most everything is made in China, now.  And quality is all over the map- from total junk to fantastic high end.  The issue is that one just can't tell quality level by saying "made in China".  Conversely, when you say "make in Japan", it usually means it is going to be good quality because they just don't service the low end market (ANYMORE... they did many years ago).
So changing manufacture of oil filters from Japan to China doesn't mean it is going to be worse quality, but it opens that possibility up so people have a totally justified reason to be worried.
