Author Topic: Shim question  (Read 3246 times)
Offline JerBear
Shim question
« on: June 11, 2015, 10:40:41 AM »
This is my first valve lash adjustment and I really didn't want to start it for fear of screwing it up.  I also didn't want to waste my money by taking it to a Stealership and having them tell me "yeah it's close enough".  Anyway I'm down to finding the shims for the final two valves, (both intake) the shim map tells me I need a (#18 or 2.175 mm) to get a final clearance of .1516 and .1643 respectively.  So far so good however, sourcing the half sized shims is impossible except for the internet and the corresponding wait during shipping.  If I use the next smaller size (#15 2.150 mm) I end up with a valve adjusted out of tolerance (loose) at .1766 and .1893 mm when the high tolerance is .17 mm and if I go thicker on the shim #20 2.20 mm I end up close to the bottom of the tolerance .1266 and.1393 respectively.  Within the tolerance of .12 mm but too darn close for my comfort and most opinions suggest going looser than tighter but IDK if going a small amount over the actual tolerance will cause issues.  Thank you for you assistance.
Jerry
2008 C14 Non-ABS
Offline Gigantor
Re: Shim question
« Reply #1 on: June 11, 2015, 12:47:37 PM »
Click on link
http://www.advrider.com/forums/showthread.php?t=435765
Here's a list of the part numbers. They only go as large as 2.450mm where the Kawasaki ones go as large as 2.750mm but you don't need any larger that 2.40mm.
SHIM, TAPPET (1.70)
14921-MBB-000
SHIM, TAPPET (1.725)
14922-MBB-000
SHIM, TAPPET (1.750)
14923-MBB-000
SHIM, TAPPET (1.775)
14924-MBB-000
SHIM, TAPPET (1.80)
14925-MBB-000
SHIM, TAPPET (1.825)
14926-MBB-000
SHIM, TAPPET (1.850)
14927-MBB-000
SHIM, TAPPET (1.875)
14928-MBB-000
SHIM, TAPPET (1.90)
14929-MBB-000
SHIM, TAPPET (1.925)
14930-MBB-000
SHIM, TAPPET (1.950)
14931-MBB-000
SHIM, TAPPET (1.975)
14932-MBB-000
SHIM, TAPPET (2.00)
14933-MBB-000
SHIM, TAPPET (2.025)
14934-MBB-000
SHIM, TAPPET (2.050)
14935-MBB-000
SHIM, TAPPET (2.075)
14936-MBB-000
SHIM, TAPPET (2.10)
14937-MBB-000
SHIM, TAPPET (2.125)
14938-MBB-000
SHIM, TAPPET (2.150)
14939-MBB-000
SHIM, TAPPET (2.175)
14940-MBB-000
SHIM, TAPPET (2.20)
14941-MBB-000
SHIM, TAPPET (2.225)
14942-MBB-000
SHIM, TAPPET (2.250)
14943-MBB-000
SHIM, TAPPET (2.275)
14944-MBB-000
SHIM, TAPPET (2.30)
14945-MBB-000
SHIM, TAPPET (2.325)
14946-MBB-000
SHIM, TAPPET (2.350)
14947-MBB-000
SHIM, TAPPET (2.375)
14948-MBB-000
SHIM, TAPPET (2.40)
14949-MBB-000
SHIM, TAPPET (2.425)
14950-MBB-000
SHIM, TAPPET (2.450)
14951-MBB-000
Re: Shim question
« Reply #2 on: June 11, 2015, 01:04:47 PM »
Jerry
some of us answered your questions on the COG forum, I don't feel like duplicating posts right now, so check the thread you have there please.
also some recent stuff here
http://www.zggtr.org/index.php?topic=19646.0
best of luck.
Offline Gigantor
Re: Shim question
« Reply #3 on: June 12, 2015, 05:49:35 AM »
Fred Harmon comments
 When I remove the cams, I will set every single intake valve to .006 inches and every exhaust to .009 inches so that you don't have to come back and get them adjusted again for a long time, and so that your engine pulls smoothly and evenly from all 4 cylinders. I'll also tighten the exhaust header bolts and I'll make sure all your wire harnesses are properly routed back the way they came from the factory, and all your panels will be reinstalled correctly.  I take my time and don't get in a hurry, so it generally takes me about 3 full days to do. Contact me if you want to make an appointment.
Re: Shim question
« Reply #4 on: June 12, 2015, 03:15:27 PM »
[...]Contact me if you want to make an appointment.
I wish he lived in my area.
Offline Gigantor
Re: Shim question
« Reply #5 on: June 12, 2015, 03:34:41 PM »
When it's my time, it will be worth a road trip to Ft Worth Texas
Re: Shim question
« Reply #6 on: June 12, 2015, 03:37:50 PM »
When it's my time, I hope to be sitting on my deck, drinking a very large beer...
Re: Shim question
« Reply #7 on: June 12, 2015, 04:23:45 PM »
"some people think they gonna die someday, I got news you never got to go"
Re: Shim question
« Reply #8 on: June 12, 2015, 07:14:32 PM »
When my time comes, I want to die quietly, in my sleep, just like my grandfather. Not yelling and screaming in terror like my grandfather's passengers.
An oldie but still funny, at least in the bad taste sort of way....
