I want to give props to Gigantor for getting us started down this path (I'm sure others have, too) and, especially, maxtog for all the work he has done recommending and showing off the JDM astar LED lights. I did my city lights the other day and just finished my front and rear blinkers and want to give some more options.
First, JDM is the real deal. I'm impressed with the lights we've found- both packaging and product. If they last as long as they should, then we have a real winner. The lights are extremely bright- way brighter than the filament bulbs they replaced- and are well worth the upgrade IMO. I purchased two pair of city lights and three pair of blinkers so I would have two spares for each application.
Here's a review of what I did, and I may have a special surprise for some of you interested in doing this project. My stuff:
![](http://www.zggtr.org/MGalleryItem.php?id=747)
My bulbs arrived directly from JDM via USPS as a 2-pack and a 4-pack (I had already removed two of the bulbs from the shown 4-pack). These were $18/pair through amazon.
https://www.amazon.com/gp/product/B00XV4W686/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1I also ordered the flasher relay shown through amazon and it works perfectly
https://www.amazon.com/gp/product/B00RM26LXO/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1. Incidentally, it is called iJDMTOY, but there's no connection to JDM astar.
Also shown is the OE flasher relay and a little square rubber bumper that fell out of the bike as I was installing the flasher relay. Anybody know where this goes? I couldn't find it, but the adhesive on one side had dried up a little, I suppose.
So here is a pic of the relay I installed upside down so that the mounting tab would just slide into the slot where the OE relay was held in place by the rubber holder. This seemed better than taking that off and tie wrapping.
![](http://www.zggtr.org/MGalleryItem.php?id=746)
For reference, here's a closeup of the OE and JDM bulbs.
![](http://www.zggtr.org/MGalleryItem.php?id=748)
Okay, now for the surprise. It seemed foolish to pull the bike apart just to change the two blinker bulbs and I wasn't looking forward to it. There had to be a better way… and there was! You don't have to take the bike apart to get to the front bulbs. Remove the two hex head screws above the chrome Kawasaki badge and the two Phillips screws in the wheel well (one is at the top corner next to the blinker lens; the other is down low near the radiator). Once you do this, you can pry back on the fairing with your finger and access the bulb socket (it's light grey with the green and yellow wires). Twist and pull out. I changed both bulbs in about 10 minutes with no stress placed on the fairing.
![](http://www.zggtr.org/MGalleryItem.php?id=749)
Being able to do that made this an especially satisfying upgrade. So now there's another source for a flasher relay and a better way to change the front bulb. Hope this helps.
