This is extremely interesting. So much so that I just put two pair in my cart...
![As long as I'm up... :popcorn:](http://zggtr.org/Smileys/default/popcorn.gif)
I'll be keeping an eye out for your report on these max', as you and I are pretty much in agreement that, so far, LEDs just don't fill the reflector (focal problems) with enough light to equal a filament bulb. However if they can tackle it another way, it appears they have 6 chips behind the projector lens instead of the usual 1, then that will work for me. I've gone over to the "light side" on LED headlights (they're not perfect yet for our reflectors, but good enough now IMO) but, like you, I've seen nothing close in the turn signals. I hope this one is it.
They're $18. The web address is below. You must have found something else for $50.
Pete, I think he was referring to the Original Post at the top of the thread.
Regardless, thanks for the link!
![finger fing 11 :finger_fing11:](http://zggtr.org/Smileys/default/Finger_fing11.gif)
With any luck (for us) you'll have to switch your front sockets back to the originals to use these...oh wait you used a Dremel...oh oh...OK, no luck for you.
![Wink ;)](http://zggtr.org/Smileys/default/wink.gif)
