I need some help with TPMS sensor installation. I removed the sensor from the back wheel of my Concours and took it to the local battery place for battery replacement ($9.99-less than a new battery shipped from Digi-Key). When I went to reinstall the sensor, after tightening the stem to the sensor, the top of the sensor is not flush with the rim. I didn't really notice if this was the case when I removed the sensor. Is this correct? Should the body of the sensor be about a quarter inch from the rim? If not, could you let me know what I did wrong? Thanks in advance.
2008 ABS Concours
