So, I'm putting in a new set of OEM front rotors and the EBC "HH" pads on my 120,500 mile 2008 C14 ABS. The last brake change (pads only) left the rear brake feeling mushy, at best. I believe I bled the brakes properly, as I've done it before and everything was fine. After a couple attempts to get the rear brake to feel better, I put a weight on the pedal over night, holding it down until I again bled it in the am. That did seem to help. I do have a hand held vacuum pump and have not tried it yet. Gettting to the question.... Does it matter which side of the rear caliper is bled first? And, does holding the brake pedal down with a weight help in getting the air up to the bleeder nipples? I've also heard that wrapping a small bungee around the brake and clutch levers for a period of time does the same. I'll probably attempt to use the vacuum pump to see how well that works too. Any tricks of the trade/suggestions/recommendations appreciated!
Joe Reiss
Kelso, WA
