Author Topic: M10x1.5 RAM ball mount. Does it exist?  (Read 2225 times)
Offline sanmo
« on: April 19, 2015, 07:35:08 AM »
My used C14 came with 1.75" risers installed. Unknown make. It has an offset accessory mount bolt hole built in, which I would like to use for GPS, etc. Problem is that it appears to be M10, 1.5 pitch while my searches have yielded only M10 with 1.25 pitch. Is there an obvious solution that I'm missing?
2008 Silverdammit C14
Re: M10x1.5 RAM ball mount. Does it exist?
« Reply #1 on: April 19, 2015, 07:44:06 AM »
Are you sure that it's an M10X1.5? It might be an 3/8-16.
« Reply #2 on: April 19, 2015, 07:44:21 AM »
The only risers w/mounts that I'm aware of is Helibars and KB's from Murphs. Both still available.
Offline sanmo
« Reply #3 on: April 19, 2015, 10:55:44 AM »
Thanks Pope & gPink. I hadn't thought of looking at the Helibar risers, but that is exactly what I have. They are indicating 3/8" x 16 thread pitch. Problem solved. :finger_fing11:
Offline mikeb2411
« Reply #4 on: April 21, 2015, 01:30:23 PM »
Or, the 2" risers from AST and then drill and tap your own holes for the RAM mount like I did  :thumbs:
Mike
Ojai, CA
2016 Black Triumph Trophy SE
Offline sanmo
« Reply #5 on: April 21, 2015, 03:09:30 PM »
 :popcorn: :popcorn: :popcorn:
