Author Topic: Raise bike for rear tire?  (Read 10365 times)
Offline timsatx
« on: April 13, 2015, 01:45:48 PM »
What do you guys do to get the rear tire high enough to remove it? I always find it a huge pain in the rear and I thought somebody might have a better mouse trap.
Offline CRocker
Re: Raise bike for rear tire?
« Reply #1 on: April 13, 2015, 01:59:48 PM »
Put the centerstand on a 2x4...
'02 C-10
Offline Vic Salisbury
« Reply #2 on: April 13, 2015, 02:19:20 PM »
After I pop out the axle, and get the rim off the hub, I remove the pumpkin (rear hub assembly) then kinda scoot the tire out sideways, because I have a hitch installed, that's pretty much the only way for me. Plus I like to inspect the hub, splines into the drive shaft, ect. anyways. Just be careful of the o-ring on the hub side splines that go into the drive-shaft.
Vic Salisbury
COG #3673
'97 Concours "Grinch"
Sarasota, FL
Offline timsatx
« Reply #3 on: April 13, 2015, 02:40:04 PM »
For me the biggest problem is actually getting it on the 2x4. The bike sits low enough that you have to work it a bit to get it onto the centerstand normally. Trying to get it on a 2x4 is the real trick.
Offline jettawreck
« Reply #4 on: April 13, 2015, 03:09:36 PM »
I put a couple 2x6 pieces parallel to the bike in front of the rear and front tires, roll it up those and then get another one crosswise under it where the centerstand will sit. After its up on the centerstand, remove the pieces under the tires.
The '02 had the rear fender trimmed. The '05 does not. Yet...
Ordered a 777HD for it today.
« Reply #5 on: April 13, 2015, 04:23:36 PM »
Put bike up on center stand as normal, rock to one side a toe a piece of 2 x 4 under one pad to which you then rock the bike the other way and toe another piece of 2 x 4 under the other pad.....
Offline TallyRex
« Reply #6 on: April 13, 2015, 06:48:52 PM »
I'm confused.  I put on a new rear last week and just used the centerstand with no clearance problem.
Offline Nosmo
« Reply #7 on: April 13, 2015, 07:21:40 PM »
I pick the whole mutha up with my engine hoist.  Can't fall over when it's hanging from chains.
http://www.harborfreight.com/2-ton-capacity-foldable-shop-crane-69514.html
Offline Cholla
« Reply #8 on: April 14, 2015, 11:53:12 AM »
I'm with Vic. It's how I've done all my shaft drive bikes. You need to service the spline/coupler anyway, and ya gotta remove the R wheel to do it. So why not at every tire change?
Offline timsatx
« Reply #9 on: April 14, 2015, 01:12:19 PM »
Do you have a rear fender? That is where the problem comes. It jams against that and you can't get it out.
« Reply #10 on: April 14, 2015, 01:22:09 PM »
I do the same. Plus my rear fender has been bobbed.
« Reply #11 on: April 14, 2015, 04:02:49 PM »
I still prefer to remove the rear end on mine as my 170/60-17 tire is not coming out even with the bobbed rear fender....
Offline JDM
« Reply #12 on: April 15, 2015, 08:16:52 AM »
I do what Mr. T does.
Offline qman
    • Autobahn Motors
« Reply #13 on: April 15, 2015, 10:53:34 AM »
I use a come-a-long hooked to the rafters of my garage
Offline Bob Young
« Reply #14 on: April 19, 2015, 09:57:55 AM »
I use the 2X6's parallel to the bike and a 2X6 under the center stand. (An '86 with no other suspension accessories). I usually need help getting the bike up on the center stand, but that method has worked for me in the past (three or four rear tire changes; and yes I lube the rear splines at the same time).
Bob Young
Offline timsatx
« Reply #15 on: April 19, 2015, 11:22:55 PM »
Are you able to get your tire out without removing anything other than the wheel?
Offline Daytona_Mike
« Reply #16 on: April 20, 2015, 06:35:33 PM »
On my bike I cannot remove the wheel from the hub because of the mean streak rim   no matter how high I  hang the wheel in the air and/or  remove the rear fender.
I do not remove the axle, I just pull it out part way and then the four bolts to the final drive.
The final drive and wheel simply rolls out as one unit.  Much easier than  wood under the stand. Much easier then trying to align the splines  when installing the wheel on the bike.  Put it together  first and then just  roll it up to the bike.
It is the easiest way to do it.
Offline Cholla
« Reply #17 on: April 21, 2015, 11:02:08 AM »
If you are lubing the splines you don't need the 2 x 6s. The wheel cmes right out after removing the bevel unit.
Offline timsatx
« Reply #18 on: April 23, 2015, 07:24:44 AM »
I'll have to give that a try.
Offline Thud300
  • COG# 12068
1998 Kawasaki Concours "Connimus Prime"
1989 Kawasaki 454 LTD "Merlin"
Workin' to ride, so I'm ridin' to work!
It's a great day for motorcycles!
