Author Topic: Noise on front bevel gears  (Read 33712 times)
Offline gildaguz
« on: April 03, 2015, 02:58:40 PM »
Bike is a 2009 non ABS with 51 k, around 50 k star hearing a noise when pushing it out of the garage , tough that might be the driveshaft splines, but having the drive shaft out I spin by hand the gear where the shaft is connected at front side and noise is coming from inside bevel gears case, any way put some moly grease to splines and put it back, there is not noise when riding it and everything is normal, noise is only when pushing it or if I spin rear wheel while in center stand,
 Any suggestion about this problem?
I check the service manual and there are a couple of parts named CAM FOLLOWER and DAMPER CAM that I suspect is where the noise is coming from, I will take it apart but would like to know if some one had this problem before.  Any advise will be appreciated
[Mod: Removed links to illegal copies of service manual site.  -Max]
« Last Edit: April 07, 2015, 05:52:09 AM by maxtog »
2009 Non ABS Concours Black
2004 Honda Shadow  Sabre 750
1979 Suzuki 185 all terrain
Re: Noise on front bevel gears
« Reply #1 on: April 03, 2015, 03:18:49 PM »
Don't think we've heard of this before.  All the noise in that area has been attributed to the splines on the shaft being a bit dry.  If you can hear it without the shaft installed that's something quite different.  Do you have an extended warranty?
Offline gildaguz
« Reply #2 on: April 03, 2015, 03:42:33 PM »
Unfortunately no, I will take apart that unit to see what I find wrong
Offline gildaguz
« Reply #3 on: April 03, 2015, 03:58:57 PM »
If you see the pictures on this unit for sale on EBAY will see that piece on the center named DAMPER CAM that work in contact with other similar named CAM FOLLOWER might be the ones that are having the problem
http://www.ebay.com/itm/11-12-13-Kawasaki-Concours-14-ABS-ZG1400CBF-Front-Bevel-Gear-13101-0119-458-/321577314452?hash=item4adf806894&vxp=mtr
Offline gildaguz
« Reply #4 on: April 03, 2015, 04:41:51 PM »
This is the recording of the noise with bike on center stand and spinning rear wheel forward by hand
https://www.youtube.com/watch?v=iL8YJJaf1i0
« Reply #5 on: April 03, 2015, 05:17:57 PM »
That does not sound good.
Offline gildaguz
« Reply #6 on: April 03, 2015, 05:47:43 PM »
But I rode today to work and everything seems normal, rode it at 90 MPH and for the first time in 4 years lift the front wheel  when I meet a coworker driving his charger getting close to work in the morning
« Reply #7 on: April 03, 2015, 06:07:51 PM »
Then that's the problem.  You're not thrashing it enough.
AlbertaDoug
« Reply #8 on: April 04, 2015, 05:56:19 AM »
 :yikes: :yikes:
Offline PH14
« Reply #9 on: April 04, 2015, 09:11:21 AM »
So you have a horrific noise emanating from the drive train and you ride it 90 MHP and also decide it is a good idea at some point in the ride to lift the front wheel? Care to name me as your beneficiary? I could use some cash.
« Reply #10 on: April 04, 2015, 09:52:56 AM »
Yeah, when I read it, I thought something similar....
Offline gildaguz
« Reply #11 on: April 04, 2015, 10:13:19 AM »
What I meant is that the noise is there only when I push it out of the garage or when  spinning the wheel over the center stand , while riding it there are no noise or vibration , every thing is completely normal, I was expecting  with this post to fin some advice from some one that have done this repair
Thanks
« Reply #12 on: April 04, 2015, 11:34:26 AM »
that's scary. I would for sure have it looked at by somebody with more knowledge than me.
Offline Rembrant
« Reply #13 on: April 05, 2015, 04:33:42 AM »
Bike is a 2009 non ABS with 51 k, around 50 k star hearing a noise when pushing it out of the garage , tough that might be the driveshaft splines, but having the drive shaft out I spin by hand the gear where the shaft is connected at front side and noise is coming from inside bevel gears case...
The bevel drives on the C14's fail once in a while...they start to click, or get loud and 'clunky'. Broken tooth, bearing, etc.
I've not heard one myself, but that's what I'd suspect.
I don't think you'll find much advice on the topic unfortunately...for most of the posts I read, the owners took their bikes to a Kawasaki dealer for repair, and then they rarely ever come back with details.
Rem
Offline gildaguz
« Reply #14 on: April 05, 2015, 08:12:12 AM »
I did not buy an extended warranty so I will repair it myself, I work as auto mechanic for the last 28 years, I will take it apart during this week , will take pictures and post the progress of the repair
Offline gildaguz
« Reply #15 on: April 05, 2015, 02:51:16 PM »
Ok things are getting complicated, after removing the drive gear unit found that is ok but apparently the noise is coming from the output shaft bearing, I recorded a video and there can be heard
Now i'm very sorry that I did not bought the extended warranty when I had  the offer
https://www.youtube.com/watch?v=XKzBjEkUkUk
Offline Rembrant
« Reply #16 on: April 07, 2015, 03:32:01 AM »
Uh oh. That doesn't sound good.
Offline gildaguz
« Reply #17 on: April 07, 2015, 02:11:16 PM »
I know, I will start taking it apart this weekend
Offline gildaguz
« Reply #18 on: April 11, 2015, 09:40:56 PM »
Finally I  start taking it apart, so far I have removed everything I can to take weight out of the engine so it will be easier to pull it down, next push will be to take it out and split it apart to find out what parts I have to order for it, it might be that I have it ready for christmas, here is a video of she taken apart
https://www.youtube.com/watch?v=9mtXNE_Wf-c
« Reply #19 on: April 12, 2015, 06:37:30 AM »
Oh crap! It looks like your bike exploded and littered parts all over your garage!    :o
2009 kawasaki concours 14 removing engine
Good luck man!!!
