Author Topic: Odd clutch problem?  (Read 4023 times)
Offline Tzigane
  • Country: nl
    • Photography
Odd clutch problem?
« on: February 24, 2015, 01:40:08 AM »
Hi guys!
Yesterday I felt an odd sensation in the clutch lever. Difficult to explain, especially when English is not my first language.
After shifting, as I'm releasing the clutch lever, I sometimes feel the lever give off a "tick", a little jab that feels as if a small resistance is being overcome. The clutch isn't slipping and allows me to get into (and out of) gear easily. It's only when I'm releasing the handle that I feel a weird lilttle "clunk" in the lever.
Does anyone recognize this?
Photography : www.masque-obscura.nl
Offline tweeter55
  • Ride Hard...Ride Safe
Re: Odd clutch problem?
« Reply #1 on: February 24, 2015, 04:43:49 AM »
Possibly look for some wear/lubricate the pivot point on the lever.
Offline Tzigane
  • Country: nl
    • Photography
« Reply #2 on: February 24, 2015, 05:08:59 AM »
Thanks. I indeed did just that. This is what I found:
92028 shows signs of wear. Could this be the problem? When i'm not riding, the lever feels perfectly fine by the way.
« Reply #3 on: February 24, 2015, 05:17:46 AM »
lol When I'm not a work I love my job.  ;)
It could be binding. I would clean and lube and see if that helps.
Offline Tzigane
  • Country: nl
    • Photography
« Reply #4 on: February 24, 2015, 07:37:33 AM »
I wish all problems were solved this easily. Put some lithium-grease on the pivot points, and everything works fine again!
Offline tweeter55
« Reply #5 on: February 24, 2015, 05:31:01 PM »
 :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana
« Reply #6 on: February 24, 2015, 05:42:57 PM »
Let's not get too excited until Tzigane tells us if he went ahead and did the other side while he was at it.  ;)
Offline tweeter55
« Reply #7 on: February 24, 2015, 08:32:30 PM »
 :1DeadBanana :1DeadBanana :1DeadBanana :1DeadBanana :1DeadBanana :1DeadBanana :1DeadBanana :1DeadBanana :1DeadBanana :1DeadBanana :1DeadBanana :1DeadBanana :1DeadBanana
Offline Tzigane
  • Country: nl
    • Photography
« Reply #8 on: February 25, 2015, 12:10:32 AM »
I indeed did.  ;)
« Reply #9 on: February 25, 2015, 03:44:41 AM »
 :thumbs:
Offline tweeter55
« Reply #10 on: February 25, 2015, 04:39:50 AM »
Offline Deziner
  • Phoenix
« Reply #11 on: February 25, 2015, 05:40:04 AM »
