Author Topic: Broken oil plug "guard"  (Read 12031 times)
Offline reesedp
  • Sail Army
« on: June 19, 2011, 06:16:34 PM »
Went out to change oil etc and found that the "guard" around the drain plug had broken most of the way off.  Expensive to replace the oil pan I imagine.  Plug was slightly damaged on one face, but was easy to repair with a file.
Offline JetJock
Re: Broken oil plug "guard"
« Reply #1 on: June 19, 2011, 06:21:06 PM »
What year bike?
« Reply #2 on: June 19, 2011, 06:32:13 PM »
scrape the bottom?
« Reply #3 on: June 19, 2011, 07:31:38 PM »
Has to be an 08/09.  10/11s have the oil plug facing the front.
Offline JetJock
« Reply #4 on: June 20, 2011, 06:47:19 AM »
Well that's what I'm ass-suming unless the OP says otherwise. If 2010/11 have to wonder how he did it. Courtesy of being a racer, I've learned never to assume that someone can't find a new and truly amazing way to break things.
Offline reesedp
  • Sail Army
« Reply #5 on: June 20, 2011, 07:14:21 AM »
I have the '08.  Possibly happened on a speed bump, but seeing as how only the center portion was gone more likely a rock I guess.
Offline JhVenezuela
  • Country: ve
« Reply #6 on: June 20, 2011, 07:54:01 AM »
I had a 2008 but paid $300 for a Oil Pan 2010.
A friend of mine had this problem two mounth ago during a trip.
« Reply #7 on: June 20, 2011, 07:57:59 AM »
JH, what parts, other than the pan, did you need?  I've been thinking about this mod for awhile but was waiting for someone else to try it first.
Offline coastalconnie
« Reply #8 on: June 20, 2011, 08:16:03 AM »
Almost did the same thing loading mine onto a trailer. The top of the ramp caught the drain plug guard but was lucky it didn't do the damage pictured above.
Offline JetJock
« Reply #9 on: June 20, 2011, 08:40:20 AM »
What? No more badminton birdie on the back of a Concours (or whatever the picture was supposed to be). Now a knight with a waving sword? Delusions of grandeur?  ;D
« Reply #10 on: June 20, 2011, 08:51:50 AM »
A speed bump could do that?  I'm gonna look at the clearance on mine.
« Reply #11 on: June 20, 2011, 09:04:40 AM »
No, checking out an avatar that is animated....  Daleks still rule of course...  Probably switch back tomorrow.
Offline JhVenezuela
  • Country: ve
« Reply #12 on: June 20, 2011, 09:10:59 AM »
I'm not sure because i haven`t installed the pan oil yet.
But all the reference including the gasket are the same between the 2008 and 2010 models.
I friend of mine must been installing the parts this week.
I'll be alert.
« Reply #13 on: June 20, 2011, 09:13:18 AM »
I'll be alert.
Please keep us updated.  I would like to add this to the C14 Wiki once you've gone through it.
« Reply #14 on: June 20, 2011, 09:17:50 AM »
Badminton birdie? You need to brush up on your classic cyborgs man!     ;D
Offline JetJock
« Reply #15 on: June 20, 2011, 01:22:22 PM »
I couldn't make up my mind as to whether it was a badminton birdie or a salt shaker. Cyborgs, classic or otherwise, were never on the short list of possibilities.
I actually kinda like the sword-swinger. More "moderator-ish"
« Reply #16 on: June 20, 2011, 01:48:55 PM »
Yep, think I'm gonna keep it for now.  Has the right emblem on it anyway...
« Reply #17 on: June 21, 2011, 05:12:33 PM »
I knew it was a robot but it always looked like a salt shaker to me.
« Reply #18 on: June 21, 2011, 05:15:49 PM »
I had a nearly identical experience with my 08.
Offline joelc1400
« Reply #19 on: June 21, 2011, 05:44:35 PM »
Scarry! my bike is lower up front 1" and 1.5 at the rear!!!
