Author Topic: Cam chain rattle [WAS: Bit O Piston Slap?]  (Read 9471 times)
Re: Bit O Piston Slap?
« Reply #20 on: January 23, 2015, 02:17:24 PM »
I used your method on the Hayabusa, when it had CCT problems back in 2000, and most owners installed an APE CCT while waiting for a cure. But it's not ideal to have a fully-manual device in there IMO, even for us who know what we're doing. And you need to adjust it periodically, just like if you had chain final drive... especially when bike is new (more stretch). The best solution is what Suzuki did with the redesigned CCT, which added a ratcheting mechanism; no more chain-slapping noise ever. Is Kawasaki still using oil-pressure alone??? Thought all bike manufacturers were using that proven oil-pressure/ratcheting design by now.
Good point. Mine had almost 50,000 miles on it when I installed the ape so I think most of any stretch is already done. The kawi CCT does of have a ratcheting mechanism but allows way too much movement. There is a slot that allows almost 1/8" for the ratcheting spring and almost that again for each notch. My bike apparently stopped stretching at just the worst point and could not get to the next ratchet point. It slapped every start up for a long time and even a little at normal idle. Completely quiet now.
Offline tomp
Re: Cam chain rattle [WAS: Bit O Piston Slap?]
« Reply #21 on: January 23, 2015, 06:46:43 PM »
Kawi is good at that, making parts that rattle around.  Ask any KLR650 owner about the doohickey.  How it better be replaced or the chain that controls the balancer will crater the engine, same problem since they were first made.  Worse with Gen 1 models, but still happens today, as the retention spring used is crap and too long.   As long as the C14 engine is not in danger, I'm ok with it.
Living in the Texas Coast...
« Reply #22 on: January 23, 2015, 06:50:12 PM »
There's no danger.  Back away from the bike.
Offline tomp
« Reply #23 on: January 23, 2015, 06:59:33 PM »
Yep.  speaking of vodka, have you tried or even have TITOS in your area?   Made in Austin,TX, and distilled six times.  It is very flavorful and smooth, over ice or as a mix.  Only type  alcohol I have consumed for at least 10 years now.  If you have it there, try it.  It won't disappoint.
« Reply #24 on: January 23, 2015, 08:10:29 PM »
Who was speaking of vodka?
Offline tomp
« Reply #25 on: January 23, 2015, 08:18:16 PM »
Jim did on reply #7, I do believe...  TITOS is good stuff, for anyone and anything that ails ya.  tp
« Last Edit: January 24, 2015, 07:21:28 AM by tomp »
« Reply #26 on: January 23, 2015, 08:48:26 PM »
Oh!  That was like 16 hours ago and on another whole page :)  Sorry, didn't even notice.  I even was scrolling back saying "huh??" and used Control-F on both pages (apparently I must have mistyped the search key).
Anyway, that will teach you for not quoting!!!
Offline tomp
« Reply #27 on: January 23, 2015, 08:54:59 PM »
Max, you are sounding way too much like my ex.   It was ALWAYS my fault, what ever it was. . .   ;D
Glad you are feeling better.  Winter time really sucks, especially here.  One day it's 70, the next 33.  Body can never adjust...tp
Offline pothole
« Reply #28 on: January 23, 2015, 09:59:35 PM »
Do yourself a favor and spend $50 and 20 minutes of time and get an ape. Not having to listen to that caterwauling every startup is well worth it.
Agree. Ordered. Ape. Thanks.
This C-14 is now my 14th bike currently...too many is never enough.
Garmin GPS, Go Cruise, Helmet locks, Delkevic 13" Carbon Tri-Oval, Mag-Knight, Lamm seat, PrjctD Wings, Guhl ECU, Advanced Sport Touring 2" Pullback risers.
« Reply #29 on: January 23, 2015, 10:05:15 PM »
Jim did on reply #7, I do believe...  TITOS is good stuff, for anyone and anything that alis ya.  tp
Never heard of it.    Currently drinking Belvedere and Effen.  I really love Effen..   Give me some Effen vodka, bar keep!  I could use some Effen Vodka.  This Effen vodka is smooth as silk.  I just love Effen vodka...  I can go on and on.  It's just so Effen good.  The C14 is Effen good!
« Reply #30 on: January 23, 2015, 10:22:53 PM »
I just love Effen [] It's just so Effen good.  The C14 is Effen good!
F'ing <snicker> :)
Offline connie14boy
« Reply #31 on: January 23, 2015, 11:26:14 PM »
Disclaimer: My APE did not come with any instructions. Videos I looked at had you finding top dead center on the engine first. I assume that was to find minimum tension on the chain. I didn't do the thing with finding TDC. Totally unnecessary IMO. Pull the OEM CCT out. On the APE CCT turn the adjuster bolt out to match the length of the OEM CCT with the plunger pushed in. With no CCT installed make sure you do not turn the engine at all. Install the APE. Turn the adjuster in by hand (no wrench) until you cannot turn it anymore. Back it out a turn. Start the bike. With the engine running, turn the adjuster in by hand until it gets tight and back it out 1/2 turn. Now use 2 wrenches to tighten the lock nut without moving the adjuster. If you remove the engine cover to find TDC it will take more than 20 min. Also takes some time to remove the right side mid faring.
Disclaimer #2: use these instructions at your own risk.
"I'm an Ape Man, I'm an Ape Ape Man, oh I'm an Ape Man. I'm a King Kong Man, I'm a Voodoo man, oh I'm an Ape Man." One of Ray Davies best tunes.
