Good crimp connectors are solid copper, have brazed joints, internal (Easy Boys! not you Nicole
) grooves to grip, have thick walls and are tin plated to resist corrosion.
Lousy crimp connectors are very thin, often brass (cheaper than copper but neither as good a conductor and not as ductile so it does not crimp as well) and tin plated to disguise the poor material used. :-)
A couple of good brands are T&B and Panduit; I personally use Panduit and find them excellent. This is an example:
http://www.digikey.com/product-detail/en/BS14-M/298-9983-ND/447757 These are not protected (so they can be crimped properly and the crimp verified) and require something like shrink- tubing to insulate them.
The crimping tool is also very important: This is an inexpensive, poor combination crimping / stripping / use bad words tool:
http://www.advrider.com/forums/showthread.php?t=847176 This is an excellent, ratcheting crimping tool:
http://www.kctoolco.com/wiha-crimper-for-non-insulated-terminals-p/43632.htm Of course, the second tool is a big ridiculous in cost for the casual user. But there are inexpensive tools that will yield an excellent crimp, such as this one:
http://www.amazon.com/Pc-Accessories-Terminal-Crimping-Installation/dp/B00EE4JW7K The other option is soldering which is also very do-able for the casual, home user. It requires a bit of skill but not a whole lot and there are a LOT of tutorials on the 'Net as to how to solder. A cheap soldering gun will suffice for any / all soldering jobs on a motorcycle. Again, some type of insulation is needed to cover the bare wires and again, shrink tubing is excellent. Electrical tape is adequate but tends to unravel, leave sticky residue all over the place and is difficult to use neatly (read: us mere mortals cannot make electrical tape covered junctions look decent).
And remember, good soldering, like good sex, is 'hot, wet and shiny'. Bad soldering.... well it is cold, dry and dull. :-)
I am planning on powering these lights off of a Fuzeblock, through a new auxiliary switch. So I don't think an additional relay isn't necessary?
Brian, please describe a "good" connector. Perhaps a link for a place to purchase.
