Author Topic: LED Light Mounting Options  (Read 12514 times)
Offline mikeb2411
« on: November 17, 2014, 10:13:32 AM »
Hey guys (and girls), I have added several "upgrades" to my bike, mainly in the way of lighting. I have 2 spots under my mirrors and had 2 LED fog lights near my front wheel. The 2 LED fogs were mounted to my reflector brackets.
A couple of weeks ago one of the reflector brackets broke, allowing the LED fog light to swing free. The light ended up being thrown back into my radiator and putting a hole in the radiator :o. I had to have the bike towed to the Kawi dealer where I had to put out some serious coin for a new radiator assembly (it was really painful) :censored:! I now have a new radiator and a radiator guard in hopes of preventing that nightmare from ever happening again!
It's obvious the reflector brackets are too weak to hold the weight and handle the constant vibration of the LED fog lights so I was wondering...those of you that are mounting LED's down low, how are you mounting them? There has to be a secure way to mount them and I was thinking about drilling through my fender to mount them but wanted to ask the group before drilling holes.
Thanks!
Mike
Ojai, CA
2016 Black Triumph Trophy SE
Re: LED Light Mounting Options
« Reply #1 on: November 17, 2014, 01:59:02 PM »
Yep, you are not the first to report it breaking.  But to have it take out the radiator in the process is a HUGE bummer.
Offline mikeb2411
« Reply #2 on: November 17, 2014, 02:07:50 PM »
I'm thinking about machining a 1" dia. x 1.188" long post (standoff) that mounts directly to the frame where the bracket is mounted/secured and using a longer screw to mount the light to that standoff, eliminating the bracket altogether. The current screw is 35mm long. 65mm would put the light just outside the fender. The longer screw would engage the same hole the bracket uses but that way there isn't thin, weak material hanging in the wind. It should be a much more secure interface. My concern is the frame piece that it attaches to...is it strong enough to handle the load put on it by the combination of vibration and weight of the light???
Mike
Ojai, CA
Offline datsaxman@hotmail.com
« Reply #3 on: November 17, 2014, 03:24:21 PM »
PIAA 1100x lights mounted to a fairly beefy short steel strap.  Bracket bolts on with one of the brake caliper mounting bolts.  Washers, longer SAE 12.9 bolt, loctite, etc.
Reflector brackets went in the trash some time ago...
161.5RWHP on the dyno
Formerly Silverdammit!
« Reply #4 on: November 17, 2014, 03:34:20 PM »
A brand new product will be introduced shortly (if it is not already out) by Twisted Throttle that will use the fender mounts to provide an aux. light mounting bracket. Give me a couple of days and I should be able to get photos for you. Of course you can also go directly to T.T. for information as well as the product.
P.S. As a matter of fact, T.T. used a particularly handsome '08 C-14 for the R&D of those brackets. Had some kind of mammal foot strung on the back of it as I remember.....  :rotflmao:
Thanks!
Offline mikeb2411
« Reply #5 on: November 17, 2014, 04:05:28 PM »
Are you referring to these?
http://www.twistedthrottle.com/denali-led-lighting-fender-mount-kit-for-d1-d2
Mike
Ojai, CA
Offline mikeb2411
« Reply #6 on: November 17, 2014, 04:12:56 PM »
Pictures??
Mike
Ojai, CA
« Reply #7 on: November 17, 2014, 04:24:13 PM »
No. What I am referring to are actual brackets, not just bolt extensions. Again, give me a day or two and let me see if I can get something to show you folks.
« Reply #8 on: November 17, 2014, 05:15:39 PM »
I bought spacers from Lowes and longer bolts for the fender bolts. (pardon the bugs)
Offline mikeb2411
« Reply #9 on: November 17, 2014, 05:15:57 PM »
Here's what T.T. recommended
http://www.twistedthrottle.com/denali-led-lighting-universal-offset-mount-kit
Mike
Ojai, CA
Offline Stephen.G.Fiddes
« Reply #10 on: November 17, 2014, 07:00:04 PM »
I plan on doing this if I ever put lower fogs on.
1982 Honda CM450E - SOLD
Offline xsv
« Reply #11 on: November 25, 2014, 05:26:34 PM »
I read about the thin reflector metal breaking.  Bought some flat steel and simply bent them to match the reflector bracket.  It is very stout.
2015 Triumph Trophy SE
Offline mikeb2411
« Reply #12 on: November 25, 2014, 06:17:22 PM »
What about the right bracket, the bracket that holds the cable (has the "hooked" bend to hold the rubber grommet), how did you handle that?
Mike
Ojai, CA
Offline xsv
« Reply #13 on: November 25, 2014, 08:50:57 PM »
The brake line runs right next to the front wheel speed sensor.  (cable with rubber grommet)  The wiring for the light runs right next to those other two.  I zipped tied them together.  The stiff brake line is not going to move and keeps the other 2 right where they need to be.
« Reply #14 on: November 26, 2014, 06:51:50 AM »
HB, what are the lights you're using? what's the output in lumens?
Offline mikeb2411
« Reply #15 on: November 26, 2014, 08:23:01 AM »
The LED's under my mirrors are 2000 lumens but dim with my Lo Beams so the 2000 is when I use HI beam.
The fogs I mount near my front when are 1100 lumens and have a 15deg  elliptical beam...great for lighting through corners.
Both lights were purchased from ADVMonster (John Sanders).
Mike
Ojai, CA
Offline mikeb2411
« Reply #16 on: November 26, 2014, 08:23:52 AM »
Sorry...meat to say "front wheel", not "front when"
Mike
Ojai, CA
Offline mikeb2411
« Reply #17 on: November 26, 2014, 08:25:15 AM »
LOL...definitely early! I meant to say "meant", not "meat" :o. Probably a good idea to quit typing until I actually wake up! :-[
Mike
Ojai, CA
Offline mikeb2411
« Reply #18 on: November 26, 2014, 08:32:04 AM »
xsv, what gauge/thickness steel did you use?
Mike
Ojai, CA
Offline xsv
« Reply #19 on: November 26, 2014, 03:06:05 PM »
1 inch wide by 1/8" thickness.  I bent them, sandblasted them and just spray painted them.  The next time I have something powder coated I will take them off and do it "right". :)
