Author Topic: Seeing the Light! AKA: Projetors from TheRetrofitSource  (Read 18349 times)
Offline Stephen.G.Fiddes
Re: Seeing the Light! AKA: Projetors from TheRetrofitSource
« Reply #20 on: October 27, 2014, 03:45:16 PM »
I updated my OP with the following
EDIT:  I've had a lot of people ask "How do you change the HID bulb when it burns out? Do I have to take it all apart?"      The answer is "No."  Changing the HID in the back of the projector, is the same exact process as changing the stock bulb.  Undo a clip, pull the bulb out, re-do the clip.  If you've got small hands like me, this may be possible with everything still mounted on the bike. (as long as you don't touch the bulb to anything)
1982 Honda CM450E - SOLD
Offline TEXREX02
« Reply #21 on: October 27, 2014, 06:06:44 PM »
Stephen,
What temperature bulbs are you running?  And what are you using for the city lights?
Gerry
'02 ZRX
'10 C14
« Reply #22 on: October 27, 2014, 06:43:20 PM »
Stephen,
Gerry
5000k 35 watt.
5000k Cree T10 LED
Stay tuned for update to the city lights... Got something else in the works when I tear the housing back apart to replace the damaged shroud. (whenever I get around to that)
Offline TEXREX02
« Reply #23 on: October 27, 2014, 08:10:39 PM »
5000k 35 watt.
5000k Cree T10 LED
Excellent!
Looking forward to the update.
Great video, thanks for doing all the hard work.
'02 ZRX
'10 C14
« Reply #24 on: November 03, 2014, 09:16:18 AM »
Updated the OP with the following link, explaining why putting HID's in a non-HID housing is a bad thing!
http://southrnfresh.com/2013/06/why-adding-a-hid-kit-to-your-car-with-non-projectors-housing-makes-you-a-ricer/
Note:  There are some vehicles with HID's with reflector housings from the factory (Earlier Volvo S60R for example).  But as you see in the link, the difference in the spacing of the light source is one of the things that changes how the light reacts to the different reflections.
« Reply #25 on: November 03, 2014, 03:32:10 PM »
« Reply #26 on: November 04, 2014, 12:13:48 AM »
Indeed, great article. Now I understand that whiter light is not always better; but I like it better, though. Anyway, I'm happy with something in the 3000-4000 K region.
« Reply #27 on: November 04, 2014, 05:44:10 AM »
Actually, he should probably add to the site that with HID technology, the higher the color temperature is over around 5K, the LESS EFFICIENT the bulb and the total light output goes down.
« Reply #28 on: November 06, 2014, 07:40:13 AM »
5k is my personal choice, although I may get some 3k to use for winter.
« Reply #29 on: February 06, 2015, 09:02:48 AM »
Going to give this a bump for the LED bulb guy... Linking his thread to this one too...
Offline fmwhit
« Reply #30 on: February 07, 2015, 03:37:09 PM »
Excellent How to Video!!
Anyone attempting this should use great caution when putting plastic assemblies in the oven. Although I have not but any motorcycle related stuff in my wives oven I did put some electronic gear in there and although the oven was set at abt 175 the plastic melted and deformed.  I guess there were hot spots as the heating elements came on to maintain the temp.
Fred
Wa2gzw
« Reply #31 on: February 07, 2015, 08:17:14 PM »
My wife would kill me if I did that.
