2 (2.7%)
1 (1.3%)
0 (0%)
3 (4%)
10 (13.3%)
0 (0%)
0 (0%)
7 (9.3%)
1 (1.3%)
0 (0%)
1 (1.3%)
2 (2.7%)
0 (0%)
0 (0%)
11 (14.7%)
13 (17.3%)
1 (1.3%)
2 (2.7%)
2 (2.7%)
0 (0%)
Did your Idle INCREASE?
1 (1.3%)
Did your Idle STAY THE SAME?
15 (20%)
Did your Idle DECREASE?
3 (4%)
Total Members Voted: 30
Author Topic: Trying to narrow down an air/fuel issue... (SOLVED! - TPS Recalibration)  (Read 83506 times)
« Reply #180 on: September 27, 2014, 07:40:31 AM »
Outstanding. This procedure is starting to sound a lot like sex.... only good!
Going to try it on my bike later today. The calibration that is.... not sex.
Judging by what others are seeing as a result of this procedure, I expect you'll see impressive results. It appears as though Mr. Steve in Florida and myself are the only ones so far that have tried this procedure with zero change.
I've been reading all the reviews and replies, and not only does it make your engine run better, but it appears to make the transmission shift smoother, and in at least one case, we have a C14 that is cornering better as well.
Please do keep us posted.
Rem :o
« Reply #181 on: September 27, 2014, 07:43:32 AM »
Why not try both Brian?    :)
Perhaps it'll turn out better than in the past and you can call it good?
« Reply #182 on: September 27, 2014, 07:44:31 AM »
Either way, could be interesting.
« Reply #183 on: September 27, 2014, 07:45:01 AM »
"Gooder", not just "Good". ;)
« Reply #184 on: September 27, 2014, 07:50:37 AM »
Well, I will never be sure but I <think> Kirby has had sex on my bike and I gotta say that just ruins it for me. I don't want to be too graphic here but the clue I found was..... dust on the seat, which is exactly what mummies leave behind.... as far as I have heard.
« Reply #185 on: September 27, 2014, 07:57:32 AM »
 :o mummy tracks?
« Reply #186 on: September 27, 2014, 07:59:21 AM »
Whoa here!  You mean certain things don't get larger with this procedure?
« Reply #187 on: September 27, 2014, 08:05:05 AM »
Stephen, can you create a poll for the ones that have tried this procedure?  I'd like to see the difference between the gen1 and gen2 bikes and whether it was perceived seemed to work or not.  I'd set it up but I'm getting ready to walk out the door..
Offline tomp
« Reply #188 on: September 27, 2014, 08:09:48 AM »
FWIW, a lot of positive post calibration results from members of the UK 1400 site.  Same thread is running there now, too.  tomp
Living in the Texas Coast...
« Reply #189 on: September 27, 2014, 08:11:15 AM »
Wow, careful on this one boys- this may well turn out to be a lot more Rorschach test than calibration procedure results test.
Are you going to put in categories for shifting, cornering, headlight brightness, etc.?
 ;) ;D ::)  ???
Edited to add: longitude, latitude, temperature, humidity and the last time you made a sizable donation to the local religious institution.
Stephen, can you create a poll for the ones that have tried this procedure?  I'd like to see the difference between the gen1 and gen2 bikes and whether it seemed to work or not.  I'd set it up but I'm getting ready to walk out the door..
« Reply #190 on: September 27, 2014, 08:12:45 AM »
Maybe the success rate goes along lines of the magnetic field? We're gonna' need a bigger pole....
Offline tomp
« Reply #191 on: September 27, 2014, 08:18:30 AM »
I believe most here would like a bigger pole...
« Reply #192 on: September 27, 2014, 08:22:16 AM »
:o mummy tracks?
https://www.youtube.com/watch?v=eB5EE42So7I
« Reply #193 on: September 27, 2014, 08:25:59 AM »
Maybe the success rate goes along lines of the magnetic field? We're gonna' need a bigger pole....(easy boys)
FIFY
« Reply #194 on: September 27, 2014, 08:27:34 AM »
Outstanding Jim- what would we do without you? We'd be a mob... just a mob. Instead of the highly refined.... mob that we are now.
Thanks!
FIFY
Offline tomp
« Reply #195 on: September 27, 2014, 08:35:28 AM »
Sure it shouldn't be IFFY, as this whole thread has shown iffy results?   Just a ponder.
« Reply #196 on: September 27, 2014, 08:52:23 AM »
I'm not sure I'd call them iffy results just yet.  Too many are receiving positive results.  The jury is still out.
Thanks!
I don't want to contemplate me not being here... :'(
Offline tomp
« Reply #197 on: September 27, 2014, 09:09:48 AM »
I agree.  Just a play on words (FIFY and IFFY).  Seems the UK riders are getting lots of positive results, with just a few nay sayers.  Something is happening, we just don't know what or why, just yet.
Offline CADMAN97
  • 2010 C14 ABS
« Reply #198 on: September 27, 2014, 11:04:23 AM »
I recently did this to my bike & yeah I think it def helped smooth fuel delivery a lot. Went out for a ride with my wife & hell yeah the bike was much smoother. Pulled away from stops nice & smooth. Parking lot maneuvers were much better. My wife even commented on how much smoother it was. It used to choke, caugh, choke some more until around 3-3.5k then it would finally respond smoothly. Not sure what it did or how it did it but to ME there was a noticable difference.
« Reply #199 on: September 27, 2014, 02:01:38 PM »
Well, the English are known for making things run well, especially if it involves electrics or electronics....
[grinnin', duckin' and runnin']
<snip>
<snip>
