Author Topic: Ignition stuck in FSS position  (Read 13013 times)
Offline Fixxer
« on: August 21, 2014, 09:39:22 AM »
My ignition is stuck on the FSS position.
I can remove the stove key and tried using the fob key, but I couldn't get it to move. It seems locked in place.
When I press downwards, I get no response from the display.
This happened this morning as I was leaving for work.
Any ideas on how to fix this? I couldn't start the bike at all.
I did a search for other relevant topics, and a common solution was to examine and clean the battery connections.
Is there anything else I could try? Is this even a electrical/KIPASS issue?
Any ideas welcomed. Thanks!
Steve
2013 C14
Nocturne Blue
Re: Ignition stuck in FSS position
« Reply #1 on: August 21, 2014, 10:06:51 AM »
Sounds like you need a KROCK or B.D.F's fix.
« Reply #2 on: August 21, 2014, 10:07:58 AM »
Where are you carrying your fob (Easy Boys!)?
I would suggest putting the active fob on the bike's saddle and again try pressing down the key. If that does not work, use the instructions in the owner's manual on how to use a fob with a dead battery.
If none of that works, you may have the dreaded 'stuck activation switch' problem. But try the above mentioned things first- let's go for the easiest solutions and work our way up to a hammer.
Offline Fixxer
« Reply #3 on: August 21, 2014, 10:25:18 AM »
Brian,
I carry my fob in my jeans pocket, and it's been like that since day one. I also recently changed the battery (within the month) in my fob. No issues whatsoever until today.
Allow me to elaborate a little. I got on the bike this morning and went through my usual starting routine. Push down, display lights up, flick start switch to run, then nothing. Display went dark. I don't know how the key wound up in the fss position, but it did.
Now, I cannot get it to move from that position. I tried removing the stove key and used the fob key with no luck. The ignition is locked in the fss position. I tried placing the fob near the key. Nothing. I had to push the bike back into the garage and drove to work. <sigh>
I'll try your suggestions when I get home from work. Thank you very much for your help and suggestions. You too, Rhino.
Steve
2013 C14
Nocturne Blue
Offline Cuda
« Reply #4 on: August 21, 2014, 10:29:18 AM »
Remove battery in bike  clean  ;)
Gods waiting room Naples
2011 Atomic  Silver
« Reply #5 on: August 21, 2014, 10:35:28 AM »
Given this information, your problem is nothing to do with any part of KiPass but almost certainly a loose battery connection. We see this issue quite often on this bike; I do not know why that is but it is common.
Remove the battery covers on the right side of the bike, remove the battery and check both battery terminals to make sure they are clean and tight- odds are, one is not tight and that is what caused your problem. While you are there, also check the ground terminal where it connects from the batter negative terminal to the frame, just in front of the battery box on the frame.
This should eliminate the problem. A sure sign that the above was your problem is that the clock will have reset because the power from the battery was interrupted.
Brian,
Offline Fixxer
« Reply #6 on: August 21, 2014, 11:13:47 AM »
Roger that. I'll check the battery and connections today.
This was also mentioned in several posts when I did a search earlier. I hope it's something as simple as that.
I'll post back to report my findings.
Thanks guys!
Steve
2013 C14
Nocturne Blue
« Reply #7 on: August 21, 2014, 11:26:16 AM »
Great- good luck with it.
I would not worry about it, as I said it is a common situation with this bike and almost certainly your problem. The symptoms match perfectly with what we so often see on this bike. And not only is it a free fix (other than your labor of course) but it seems to be a permanent fix; once snugged up, the terminals seem to stay tight.
Thanks guys!
« Reply #8 on: August 21, 2014, 12:27:51 PM »
Have hammer.  Let me know when you need me.  :salute:
« Reply #9 on: August 21, 2014, 12:29:10 PM »
I don't have a hammer but I do have a rock  ;)
« Reply #10 on: August 21, 2014, 01:42:03 PM »
Absolutely primitive....sigh.
« Reply #11 on: August 21, 2014, 02:28:13 PM »
Better save it Jim- I understand more vehicles will soon include KiPass (or HoPass, or SuzPass, etc.).
Take a look at this:
According to Kirby (I do not read Japanese, and I am not sure he does either) this article is blaming the plane crash in the photo on the LACK of KiPass and is urging the Prime Minister and the entire gov't of Japan to pass legislation requiring it on all new vehicles built.
Like I said, I don't read the language but that's what the little fella' tells me....
Offline Fixxer
« Reply #12 on: August 22, 2014, 09:22:29 AM »
Brian and Cuda were spot on!
Checked the battery and connections after I got home and found that both were loose. I removed the battery, cleaned up the connections and reinstalled. I also checked and cleaned the ground connection.
Hit the key, and it unlocked! Rode to work, and everything is back to normal.
***THANK YOU*** to Brian, Cuda, and everyone who helped. You guys saved me time and possibly a unwanted trip to the dealer.
Hopefully I can help someone here the way you guys helped me. Mahalo!
Steve
2013 C14
Nocturne Blue
« Reply #13 on: August 22, 2014, 09:51:41 AM »
Great- glad it was that easy.
We have seen this quite a lot on the C-14, and given the symptoms it was an easy and almost certain diagnosis.
Now go ride the pants off that bike- you are in a beautiful area for it!
« Reply #14 on: August 22, 2014, 11:15:52 AM »
Too bad the Hawaii state speed limit is 60 mph.  :-\
« Reply #15 on: August 22, 2014, 11:22:46 AM »
And all the straight roads curve to the left or right to avoid the water :-)   Still, the weather there is fantastic and that has got to make it easy to plan a bike ride / rally four months in the future without having to wonder 'I hope I can ride that day'.
« Reply #16 on: August 22, 2014, 11:28:08 AM »
+1 I've rented bikes on Kauai and Maui. Fantastic to just cruise around and enjoy the scenery and weather. But you definitely can't be in a hurry.  ;)
Offline Cuda
« Reply #17 on: August 22, 2014, 04:11:33 PM »
Getting fuel last night my gas tank lock was sticking , was not rotating back , sprayed some Boeshield T-9 all is well .
www.boeshield.com
2011 Atomic  Silver
« Reply #18 on: August 22, 2014, 05:11:41 PM »
www.boeshield.com
"The formulation, based on a unique combination of solvents and waxes"
I wouldn't use that in any of MY locks (wax).  But the problem with the gas tank lock is pretty common on most (all?) Kawasakis.  I just spray some graphite in the lock and on the latches about once or twice a year.
Offline aspire61
  • 08 concours + 85 madura 1200
« Reply #19 on: August 22, 2014, 06:19:07 PM »
Just one question- Do you use a baterry tender?
No mans opinion is entirely worthless- even a broken watch is correct twice a day.
