Author Topic: upgrading battery!!  (Read 2644 times)
Offline gtr a14
upgrading battery!!
« on: August 17, 2014, 12:32:29 PM »
Hey, im runing the standard yb18 battery, i often have sat nav, phone running lights and spot lights on.
Should i get an upgraded battery and if so what do i get? :-\
Re: upgrading battery!!
« Reply #1 on: August 17, 2014, 01:36:48 PM »
Has this one not been working?
Offline Outback_Jon
« Reply #2 on: August 17, 2014, 02:43:40 PM »
If you're having trouble with the amount of power you are drawing, a bigger battery isn't going to help.  It might mask the symptoms a bit, (if you put the bike on a charger between rides) but in the long run, you're going to have to upgrade your alternator to a ZZR alternator, or decrease how much you are drawing from the battery.  LEDs can help with that.  I run a set of LED driving lights where I used to use halogen lights.  54W total now where I used to have 110W.  I've got an LED headlight that I like - 20W on low, 40W on high.  (vs. 55/60 on standard H4)  Replacing the running/brake/turn lights with LEDs can save some wattage, too, but you'll need to replace your blinker relay as well.  And the dash lights can be replaced saving a few more watts.
How much wattage are your spot lights and running lights?  (I wouldn't worry about the phone and GPS - those generally don't use enough to be an issue.)
Offline gtr a14
« Reply #3 on: August 18, 2014, 03:20:12 AM »
Yeah its working but sometimes find it hard to start, so assumed the battery was struggling with the draw on it !
Offline gtr a14
« Reply #4 on: August 18, 2014, 03:28:38 AM »
HI, spots are about 50w, the running lights are led so only about 9w. Will replace the spots have ordered led spots from internet, i have changed dash bulbs to led so will now replace brake/turn etc too.
And if all else fails will change alternator ( got plenty of led bulbs) cheapest fix is best !!  ;D
Offline SteveJ.
« Reply #5 on: August 18, 2014, 01:45:08 PM »
Are you running a volt meter? Highly recommended iff'n you have electronical farkles.
Is this on a C-10 or 14?
America's Seaplane City
Offline gtr a14
« Reply #6 on: August 19, 2014, 04:31:28 AM »
No not running a voltmeter, its on my c10, voltmeter sounds like a plan!  :)
Offline tweeter55
  • Ride Hard...Ride Safe
« Reply #7 on: August 19, 2014, 05:46:54 AM »
Offline SteveJ.
« Reply #8 on: August 20, 2014, 07:02:09 PM »
I've got this one on my C10 and like it a lot.
http://www.motorcycle-superstore.com/8115/i/kuryakyn-led-battery-gauge
That's the same volt meter that I use. Mine has several years and over 100,000 miles on it with no issues.
The LED's are a bit bright, though. Nothing that some 90% window tint couldn't cure.
