Author Topic: Engine cuts out at moderate throttle opening  (Read 10835 times)
Offline datsaxman@hotmail.com
Re: Engine cuts out at moderate throttle opening
« Reply #20 on: July 30, 2014, 01:55:14 PM »
Thanks, Jeff
If you read the thread, you know that I replaced the filter right before the rally, so I have the part number.  But thanks...
Yes, it may be a hot weather/venting issue.  In 1500 miles since returning from the rally, I have not been able to duplicate the problem.  Yes, it has been warm, and I have run the fuel down to the LOW FUEL point.
Shiny new pump and two even shinier new filters await.  I think I will pull the tank lid/vent goodies apart and see what is going on there.  I will pull the pump n filter later when I do the big Valve Clearance and Plugs Day.  Soon, but apparently no need to hurry and fix the pump.
Maybe the threat of replacement has made the pump behave.  Go ahead and laugh.  I have been doing this maintenance business for a while, and have seen it happen too many times...
saxman
161.5RWHP on the dyno
Formerly Silverdammit!
« Reply #21 on: July 30, 2014, 04:39:25 PM »
I won't laugh.  I face this with computer systems and equipment ALL THE TIME.
« Reply #22 on: July 31, 2014, 04:49:08 AM »
Offline Stephen.G.Fiddes
« Reply #23 on: August 01, 2014, 12:39:34 AM »
This happened today.... Starting from a stop, into a right-hand turn, BARELY had the clutch engaged, throttle twisted about 25-35%, engine caughed and died.... Thank God for Canyon Cages!!!
That said, my bike has been doing this more and more... In a straight line, while accellerating from a stop, it will surge for quite a distance until I let off the throttle, or pull the clutch and blip the throttle. Even with a warm engine.   This is the first time its actually died tho.
90* ambient when the engine died.
New gas from one of the 3 stations I frequent (which are all very busy)
Hot-o-meter at 1 bar above center.
9,500 miles on the bike.
Had ridden about 200 yds from where I was parked, stopped at a stop sign, went to pull away and she sputtered and died.
Ill have to see if i can get it on video sometime soon. I usually forget i have my GoPro running when it happens so i forget to stop the recording so it doesn't get erased.
Do I take it to the shop for warrenty?  Or just nut up and fox it myself? (Which I'm fully comfortable doing, but i don't want to void the warrenty)
1982 Honda CM450E - SOLD
« Reply #24 on: August 01, 2014, 04:12:08 AM »
I would take it in to the dealer.
« Reply #25 on: August 01, 2014, 01:39:07 PM »
Agreed.  Let the dealer look at it.  Especially if you are on the warranty.  Maybe the dealer finds a loose or damaged connection or component.
Maybe they put in a nice shiny new fuel pump so they can get that old fuel strainer out of there.
Doesn't sound like the same conditions as mine...after a fill, mine is/was always fine.  After opening the tank, mine usually better.
saxman
« Reply #26 on: August 03, 2014, 11:05:29 PM »
Alright, when i get a chance, ill get it into the dealer.  Been stupid busy lately
(Hence why i havent been to the shop yet to get that vid for ya saxman... Havent forgot)
« Reply #27 on: August 04, 2014, 08:01:36 PM »
Appreciate the thought...
« Reply #28 on: August 11, 2014, 08:24:46 PM »
Hey, another thought hit me yesterday which i am going to persue (as its not covered under the warrenty)
Throttle body sync...
All of the symptoms match what im experiencing:
-Viberations in the bars
-Runs rough on at low end (cold especially, hot too)
-Throttle isnt perfectly responsive
-Hesitation has also become an issue
Im going to chase this down and see what happens. As soon as I can get my hands on a set of [sync gauges].
