Author Topic: Manual Cam Chain Tensioner  (Read 18313 times)
Re: Manual Cam Chain Tensioner
« Reply #40 on: October 13, 2014, 03:53:04 PM »
You can see in this pic the OEM CCT has no gasket stuck to it. If indeed there was one stuck to the head, then I just reused the original gasket. Otherwise you can also see the original did not leak at all. So I'm not worried.
