Author Topic: New farkle arrived and installed - tail light  (Read 58079 times)
Offline gildaguz
Re: New farkle arrived and installed - tail light
« Reply #160 on: February 03, 2012, 07:23:31 PM »
Received and installed the clear lens version, and connected the turnsignals. Very happy with the results. A nice up-grade!
where you order it from, can you post a link? thanks
2009 Non ABS Concours Black
2004 Honda Shadow  Sabre 750
1979 Suzuki 185 all terrain
Offline SVonhof
  • 2009 C14
« Reply #161 on: February 03, 2012, 08:14:04 PM »
Apparently, the seller is no longer listing them on Ebay. It was by a seller called "divintymotor".
Scott
« Reply #162 on: February 03, 2012, 08:22:17 PM »
I listed the links to buy on page one of this thread.
As SV said though it looks like he no longer has them listed on ebay, but you can shoot him a message through ebay with an inquiry, you never know maybe he has a couple left over...
Offline gildaguz
« Reply #163 on: February 08, 2012, 05:37:16 PM »
I did it and they respond sending me a link of the other store they have, i did order the clear one
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110782008116&ssPageName=STRK:MESE:IT#ht_8628wt_1139
Offline SVonhof
  • 2009 C14
« Reply #164 on: February 08, 2012, 05:43:09 PM »
gildaguz, glad to hear you were able to get one still! Good news for others who are just finding this thread as well.
ZG, wanna update your initial post with the new link?
Scott
« Reply #165 on: February 08, 2012, 05:58:59 PM »
That's awesome G, glad to hear it worked out and these are still available!!  :thumbs:   8)
I just updated the ebay buy links, good idea SV!  ;)
Offline OCK913
    • The Orlando Riders Club
« Reply #166 on: February 08, 2012, 06:05:05 PM »
Just dont forget to add the diode!
http://www.zggtr.org/index.php?topic=5676.0
            2009 Kawasaki C14 - Black
Offline gildaguz
« Reply #167 on: February 08, 2012, 07:20:17 PM »
I have HYPERLITES installed, so  should i use the diode?
Just in the brake light wire, not in the driving light wire?
Offline OCK913
« Reply #168 on: February 08, 2012, 08:16:45 PM »
Just in brake light wire. You can get a 3 amp diode from Radio Shack and place it inline between the brake light and the harness plug. If you tap in to that wire for your hyperlights, tap in before the the diode. You dont want anything between the diode and the brake light. The diode can only go one way so if you install it and things dont work, turn it around the other way. It is basically a one way valve, current can flow thru it one way, but not the other.
Offline gildaguz
« Reply #169 on: February 24, 2012, 06:06:29 PM »
OK i did install  tail lamp today, i did put the diode on and after installed  measured voltage at the blue wire ( green in the new lamp) before the diode was almost 7 volts and with the diode still show about 0.4 volts, I'm posting pictures with both lamps lighting at the same time one next to other so the difference can be seen ( did use a battery and jumper wires to power up the stock lamp), the difference is more noticeable with the driving lights than with brake lights
i did cover the HIPERLYTES with black tape
Driving lights
Brake lights
Offline momo65
« Reply #170 on: February 24, 2012, 06:14:07 PM »
i like that, am ordering one of them, i have a top case and always kind of afraid someone behind me not seeing the brake light, this should work pretty good, thanks.
Offline momo65
« Reply #171 on: February 29, 2012, 02:57:43 PM »
not bad for the price, the OEM light is not as bright as i would like it, might have to give this one's a try or get the admore light system, decisions decisions.
« Reply #172 on: March 04, 2012, 08:48:48 PM »
Driving lights
Brake lights
Very nice G!  :thumbs: :thumbs:
