Author Topic: Spark Plugs  (Read 9857 times)
Re: Spark Plugs
« Reply #20 on: April 15, 2015, 06:55:35 AM »
I replaced my plugs when I did my valves at around 30k. I don't think they needed replacing but since I was in there anyway, might as well. Will probably replace again when I do the valves again around 60k this year some time.
Re: Spark Plugs
« Reply #21 on: April 15, 2015, 08:58:25 AM »
The center electrode makes no difference in end- gapped plugs, and iridium plugs gap like any other, common, spark plug- by bending the outer electrode. According to the Kawasaki manual:
Electrical System
Spark Plug:
Type NGK CR9EIA-9 – – –
Gap 0.8 ∼ 0.9 mm (0.031 ∼ 0.035 in.) – – –
Mine were all gapped at 0.035" at 25K miles and all w/in 0.001" of that at 50K, when I changed them.
New plugs are all have the proper gap from the factory but I check them just in case they were bumped and have found the occasional plug with a significantly smaller gap, though never with a larger gap than spec'd.
There are a few types of spark plugs that the gap cannot be set on but they are not used in normal street vehicles. The surface gap spark plug is a great example: the gap was determined by the machining diameters and fixed by the porcelain that holds them apart. Nothing short of a vice and a hammer would alter the gap and to actually do that the plug would be ruined anyway (crushed porcelain).
https://www.google.com/search?q=surface+gap+spark+plugs&biw=1920&bih=1019&tbm=isch&imgil=7YB9ZwujC5KR1M%253A%253B1K69lrNAQzeYTM%253Bhttp%25253A%25252F%25252Fwww.formula1-dictionary.net%25252Fspark-plug.html&source=iu&pf=m&fir=7YB9ZwujC5KR1M%253A%252C1K69lrNAQzeYTM%252C_&usg=__6565n2NRdqC9wuy9Tji99wTA2jg%3D&ved=0CEUQyjc&ei=_3suVbaBKYarggSXgoTYDQ#imgrc=uA5jYn-89spTGM%253A%3BzKBxBC1bdI_lcM%3Bhttp%253A%252F%252Fwww.ngkntk.co.jp%252Fenglish%252Fproduct%252Fsparkplugs%252Fsparkplugs%252Fimg%252Fpl014.jpg%3Bhttp%253A%252F%252Fwww.ngkntk.co.jp%252Fenglish%252Fproduct%252Fsparkplugs%252Fsparkplugs%252F%3B210%3B188
