Author Topic: Parting out 1994 Kawasaki ZG1000 Concours  (Read 2372 times)
Offline krashpartllc
« on: April 27, 2014, 07:35:29 AM »
Parting out 1994 Kawasaki ZG1000 Concours, bike had 41k miles on it when wrecked and did run before dismantle. This model was produced from 1989 to 2006
Front Brake Proportioning Valve   $10.00
Rear Caliper Bracket   $5.00
Front Brake Hose (2)   $20.00
Rear Brake Torgue Link   $15.00
Front Brake Line (From Master Cylinder)   $10.00
Rear Brake Pedal w/ Master Cylinder   $20.00
Rear Brake Hose   $10.00
Rear Brake Caliper   $25.00
Rotors, Front & Rear   $95.00
Oil Cooler with Lines   $50.00
Motor Mount Bolts   $10.00
Carb Set   $180.00
Exhaust Header   $70.00
Motor   $360.00
Ignition coils and plug wires (Accel Wires)   $45.00
Left Handlebar Switch Assembly   $27.00
Right Handlebar Switch Assembly   $35.00
Starter Relay w/ Battery Lead   $15.00
Alternator   $50.00
Igniter, Ignitition Module   $52.00
Starter w/ battery Lead   $49.00
Oil Presure Sending Unit   $10.00
Radiator Cooling Fan   $30.00
Gauge cluster   $68.00
Horns (2)   $10.00
Fuse (Junction) Box   $15.00
Rear Brake Light Switch   $10.00
Ignition Switch & Locking Gas Cap w/ Key   $46.00
Ignition Switch cover   $5.00
Kick Stand Safety Switch   $10.00
Wiring Harness   $65.00
SAE Battery Tender Cable   $10.00
SHAFT-SWING ARM,Left, Pivot    $10.00
CAP,SWING ARM,Left   $10.00
Front Axel   $15.00
Rear Axel   $15.00
Drive Shaft Assembly   $65.00
Rear Air Shock   $65.00
Drive Shaft Boot   $5.00
Rear Shock Link   $25.00
Forks (2)   $169.00
Final Drive   $99.00
Triple Tree   $55.00
Speedometer Drive   $10.00
Swing Arm, Complete   $89.00
http://s1000.photobucket.com/user/krashpartsllc/library/1994%20KAW%20Concours
Offline dboogie2288
    • Beginnerbikers.org
Re: Parting out 1994 Kawasaki ZG1000 Concours
« Reply #1 on: April 27, 2014, 08:52:36 PM »
I'll take the Jbox for 15!
If you want to send me a paypal invoice at admin@beginnerbikers.org
Is the KAW service manual for sale? Did i miss it in the text?
Offline gregman_1
« Reply #2 on: April 30, 2014, 02:57:19 PM »
PM sent!
2005 Concours-"The Other Woman"
Stock except Canyon Cages and heated grips
Offline n4xae
« Reply #3 on: August 16, 2014, 09:03:22 AM »
Do you still have the alternator and bolts for sale? If so, send me your #, I have a Memorial Run next week for my riding buddy need ASAP. Or you can call me and I'll call you back  (850) 995-0816. Thanks
« Reply #4 on: August 17, 2014, 03:36:03 PM »
PROSPECTIVE BUYERS PLEASE NOTE:
THE SELLER IS INCORRECT ON HIS POSTING WITH REGARDS TO THE DATES AND COMPATABILTY ON PARTS APPLICATIONS.
HE IS SELLING A 1994 Concours parts grouping, many of these parts only fit 1994 thru 2006.
If you have a 1986 thru 1993 you need to make sure you don't mistakenly purchase the folowing;
Gage cluster
Anything dealing with the front axle or forks
Various plastic parts primarily front fairing
Front brake parts
While we thank him for coming here to offer, he has obligations to at least get it right....
