Author Topic: Cam Chain Noise  (Read 1552 times)
Cam Chain Noise
« on: April 24, 2014, 06:30:25 AM »
Old topic I know. But my 2010 with 44,000 miles on it started making the cam chain noise even when warm. I'd be sitting a light and get the noise. I could increase rpm slightly and get it to go away. Over a period of a week it started getting worse. I've been commuting on it and working long hours and I haven't given the bike any TLC in the last few months. I checked the oil and nothing in the sight gauge :yikes: I added oil and it was 2.5 quarts low! I knew my valve cover was leaking a bit but obviously leaking more than I thought. After topping off the oil, the noise went away completely (except the normal 2 seconds after cold startup).
So I was wondering if I was actually loosing oil pressure. No indication on the panel but why else would the CCT start backing off in normal riding? Still runs fine but wondering if I damaged the engine at all.
Re: Cam Chain Noise
« Reply #1 on: April 24, 2014, 06:35:06 AM »
Don't know- the oil pressure lights are usually set to trigger at a pretty low rate, meaning the oil pressure could be quite low before the oil pressure light actually goes on.
2 1/2 quarts low should have left puddles all over the place if it was leaking out of the engine. ??
Re: Cam Chain Noise
« Reply #2 on: April 24, 2014, 07:27:42 AM »
Been 7500 since last oil change. So yes, small puddles must have been left all over Colorado and Texas but I never noticed. None under the bike in my clean garage when I left 2 months, 4000 miles ago.
Re: Cam Chain Noise
« Reply #3 on: April 24, 2014, 07:29:54 AM »
1 qt every 3000 miles. Sure hope its not burning that much.
