Author Topic: Blown fuse help  (Read 5867 times)
Offline Jet86
  • California
Re: Blown fuse help
« Reply #20 on: June 14, 2011, 04:15:24 PM »
The easiest way to find the problem is to replace the fuse with a chunk of wire.  Once you find where the smoke is coming from you have found the problem.
OK not a lot of help, but it made me feel better.  I hope you figure this out.
 :rotflmao:LOL when i was a kid i actually done that, yep found the bad wire but then it melted the rest of the good wires along with it..
Ok I'm going out and try to use a thin long screw driver threw that front plastic vent and just push the connectors off the horns...
Re: Blown fuse help
« Reply #21 on: June 14, 2011, 04:54:47 PM »
Better yet use a .22LR bullet..... NOT
Offline Jet86
  • California
Re: Blown fuse help
« Reply #22 on: June 14, 2011, 10:30:26 PM »
Problem solved! Thanks to everyone who pitched in, It was indeed the horn so i went ahead and removed it and there will Never be any horn stuck in that spot again as long as i own it, I pulled the horn wires down and taped them off and zip tied them in place for now.. A Horn is a must on a bike so i will get another one soon as i can but it wont go in the same spot that's for sure. I probably should scoot over to the horn topic now and see its all about.
Thanks Again!
:chugbeer:
