Author Topic: 1994 - Remove Fairing Grill  (Read 3571 times)
Offline oldsmoboat
« on: April 12, 2014, 10:52:23 AM »
How is this grill removed?
TIA
Offline Nosmo
Re: 1994 - Remove Fairing Grill
« Reply #1 on: April 12, 2014, 12:23:54 PM »
Option 1:  Bash it out with a hammer.
Option B:  Remove the fairing.
It is attached to the fairing from the inside.  You can't access anything meaningful behind it anyway.  The horns are behind it, but they won't come out through the opening. If you want to do anything back there you'll have to pull the instrument panel, or the whole fairing.
pic below
Offline oldsmoboat
« Reply #2 on: April 12, 2014, 12:55:24 PM »
Hmmm, looking to pull the wiring from horn to hook to a relay to use a new horn.  I guess it will wait till it warms a bit and I put the shorter windshield on.  Do it and add accessory port for 12v.
Thanks.
Offline Rick Hall
  • Eruption
« Reply #3 on: April 12, 2014, 09:04:42 PM »
Pretty near have to remove the main fairing to get to the horns. When you do that, busting the grill out (to get to the horns) is moot.
Removing the main fairing is a five minute job, once you've done it a few times. Remove middle fairings, the inner pocket fairings, the windscreen, the dash cowling, the mirrors. Remove (twist out) the turn signal bulb socket assembly, remove the main fairing.
#2 and #3 phillips screwdriver and a 10mm wrench is all you need.
Rick
« Reply #4 on: April 13, 2014, 10:46:07 AM »
If you just want to get to the wires, you can reach them from the bottom, remove the little plastic filler down front, voila....
Offline Jet86
  • California
« Reply #5 on: April 14, 2014, 05:37:33 AM »
Just want to add that i removed my horn assembly and did not need to remove the faring, it was so long ago i can't remember how' all i know is i did not need to remove the fairing, but it was a bugger and took some time, i could be wrong but i think i removed my windshield and instrument cluster to get to it
Offline RFH87_Connie
« Reply #6 on: April 14, 2014, 07:58:19 AM »
To answer the original question, that grill is not "removable".  It is melted into position at the factory.  It has little posts that serve as rivets when they are melted.  When I repainted, I ground them down to remove it for painting.  Then re-adhered it with a Lego and MEK slurry after painting.  In hind sight, I probably didn't need to, but they were painted separately at the factory.
Offline Uded2me
This forum is dead dead dead
« Reply #7 on: April 15, 2014, 10:29:28 PM »
d e a d
« Last Edit: February 21, 2016, 09:29:43 PM by knight_mare »
Offline oldsmoboat
« Reply #8 on: April 17, 2014, 06:15:34 PM »
Thanks, all.
