Author Topic: battery  (Read 9268 times)
Re: battery
« Reply #20 on: April 17, 2014, 04:32:41 AM »
sorry to revive this thread, but I'm taking the bike for maintenance next week to the dealer (yes, I like/trust them) and still not sure I need a new battery. I'm reading 14.4V when riding, 11.9V when left over night. Bike starts fine when cold, it only takes a second (I mean literally 1 second, 1 and 1/2 tops) and I never had to push the button twice. Battery is OEM 2008.
What signs to look for? Or am I just being cheap/paranoid?
11.9v is too low, it should be over 12v. The 14.4v means that your generator is putting out the required voltage to charge the battery but the battery isn't able to store 12v any longer.
Re: battery
« Reply #21 on: April 19, 2014, 10:18:34 AM »
Mine is only 3 years and seems to be failing.  I think it was permanently damaged because it sat depleted at least twice.  So I am in the market for one too.
I ended up just buying an OEM Yuasa YTX14-BS off Amazon.  http://www.amazon.com/gp/product/B000WJX4BQ  $69 with free shipping.  It arrived Thursday- had to install the acid, let it sit 30 min, then charge it an hour, then rest two hours, then test voltage.  Installed it on Friday.  During that, I tested the "off/standby" current drain on the bike- it was 80mA for the first several seconds, then when the computer goes into full sleep, it was pulling 2.5mA, which seems reasonable to me.
Bike starts SO much better now.  The old battery was fully charged... it has sat now for only 18 hours on my workbench, and it at 12.54V.  I have seen worse.... like I said before, I think it just has much less depth to it.  Anyway, the new battery should last much longer, since now I always use a Battery Tender Jr. (I have over the past year, but it was apparently too late for the original battery).
(New tire pressure sensors, new tires, new battery... I am on a roll.  Now I just need to change the oils, tighten stuff up, and get that Throttle Tamer installed)
Re: battery
« Reply #22 on: April 20, 2014, 06:33:39 AM »
snip...
Is that 2.5mA after the red LED stops flashing?
Re: battery
« Reply #23 on: April 20, 2014, 07:25:15 AM »
No, that is about 15 or 20 seconds after the larger current draw but still while the red LED is whittlin' away. The LED does not show up as a pulse of current so I suspect there is a capacitor feeding it and it is averaged out in the 2.5 milliamp standby current use.
Now the way to tell would be to shut the LED off and test it that way, which I have not done. For shame Brian, for shame....  ;D
Offline connie14boy
Re: battery
« Reply #24 on: April 20, 2014, 07:34:12 AM »
Max, there is a YTX14-14 AGM battery available at Battery Mart.com for $49.95 w/free shipping.
Re: battery
« Reply #25 on: April 20, 2014, 08:34:25 AM »
Or wait 24 hours after you shut the bike down, keeping the ammeter connected of course.
Offline Daytona_Mike
Re: battery
« Reply #26 on: April 20, 2014, 10:36:52 AM »
This is the same AGM battery sold at AutoZone for $109
I got it for $41 delivered.
http://www.ebay.com/itm/231172565275
Re: battery
« Reply #27 on: April 20, 2014, 12:16:01 PM »
You guys got wayyyy toooo much time on your hands.
Re: battery
« Reply #28 on: April 20, 2014, 08:27:01 PM »
I was going to say something similar.  My meter is pretty fast, and I never saw any change at all with the flash of the LED.
Re: battery
« Reply #29 on: April 20, 2014, 08:28:59 PM »
I knew it wasn't the best deal, but I had other stuff to order from Amazon, plus I already have an account, plus I needed it before my trip yesterday (which actually turned out to be today).
Offline TJ
Re: battery
« Reply #30 on: April 20, 2014, 09:18:36 PM »
Well, if you saved the OEM battery CASE, and placed the new mini battery inside it.... it would be a better battery..... 8) to do a Colorado run.... but I don't know anything about that stuff..... :-[
as for new batteries, I'll resurrect these guys, price went up a bit, but delivery is uber fast, I got mine in less than 48 hours from calling in an order, website purchase may add a couple days.... I suggest calling them....
http://www.batterystuff.com/powersports-batteries/sYTX14-BS.html
I ordered one from these guys a week ago and it still hasn't arrived yet. Luckily I am in no hurry but if you are looking for fast delivery I can't recommend them.
2012 Black Kawasaki Concours
Re: battery
« Reply #31 on: April 21, 2014, 11:49:54 AM »
I highly suggest you call them....
when I made my order, I called, and asked if it was in stock, I pretty much do that on everything I order when it is an "emergency--I need it quick", or if I simply don't want to give my charge card out online...
anyways, when I called them the battery was in stock, so I just placed my order via phone...
as I noted, it was at my Ohio home in less than 2 days.
they ship USPS Priority mail... I wouldn't blame them, but I would blame the mail....
call. ask them for the tracking number.... my bet is the USPS screwed up, and your package is coming back from visiting Maine, and Florida....
Offline TJ
Re: battery
« Reply #32 on: April 21, 2014, 01:17:34 PM »
I did call them on April 18th. They offered a tracking number but I declined writing it down. The purpose of the call was just to make sure they got the order (which they did) because it was placed online. So I know the battery was in stock and shipped. I just don't have it yet.
Offline AZ-ZG
Re: battery
« Reply #33 on: April 21, 2014, 09:13:54 PM »
FYI, Just another option, pricey, lighter.....
http://shoraipower.com/products?action=vehicle&type=175&make=1057&model=7876&year=7876
It's my understanding that the Shorai batteries are not ideal for bikes that have things *running* while off.  Clocks, flashing red LEDs in the gauge cluster....
May not be an issue in a daily driver?
Would you really notice a lighter battery in a 600+ pound moto?
Replaced with AGM from O'Reilly.  Had to have it so I bit the bullet. Dirty Grrrl is my daily driver/do it all fun time machine!  ;-)
I live. I ride. I am. ZG14
IBA#53928
Re: battery
« Reply #34 on: April 21, 2014, 10:15:03 PM »
It's my understanding that the Shorai batteries are not ideal for bikes that have things *running* while off.  Clocks, flashing red LEDs in the gauge cluster.... [...]Would you really notice a lighter battery in a 600+ pound moto?
Yeah, the weight thing doesn't hold much weight for me (har har har).... I think the advantages would be mainly the energy density and possibly longer life.  But I don't think it is worth the price difference as a lead acid replacement for non-electric vehicles.  That is why I haven't bothered looking at lithium.
Re: battery
« Reply #35 on: April 22, 2014, 07:09:18 AM »
Alrighty then... called Friday, posted Sunday...? you say you can't recommend them for fast shipping, and you decided not to track your shipment.... :thumbs: :thumbs:
that Colorado Gold must be some good stuff man.....
 :rotflmao: :rotflmao: :rotflmao: :rotflmao: :rotflmao:
Offline TJ
Re: battery
« Reply #36 on: April 22, 2014, 10:25:26 AM »
I am simply not in a hurry. My point is they currently do not have fast delivery times and I just wanted to make others aware. My order was placed on 13 April and as of today, 22 April it has not arrived yet.
Tracking a shipment doesn't make it come any faster. But I did find out it was out for delivery today via UPS. Perhaps their shipping times have increased because someone reported they shipped via USPS but this order was sent UPS. That means 7 business days after the order was placed from Oregon to CO.
Re: battery
« Reply #37 on: April 23, 2014, 12:33:05 AM »
Didn't you say it was starting weakly at the beginning of this thread?  Now it's ok?  Anyway, my 2002 C10 did over 5 years on it's original battery and I changed it because of the years on it.  I think you would be wise to change it out on your bike with the number of years it has.  If you've had good luck with the OEM then get that brand.  I would.  I changed mine (C14) at 3 years (nothing wrong with it) because I was going cross country and wanted to make sure that the battery would not be an issue.  I would stop stressing out on it and just do it.  We've given you some alternate battery resources but we don't know what's available in Germany.  I'm sure the OEM battery is available there.
Well, dropped the bike at the dealer yesterday. He asked me a few questions regarding how the bike starts, etc., and told me not to replace the battery. It's just fine and there's no reason to spend money on a new one. I have to admit that he has a point in that I'm a long distance driver, so when I start the bike I usually empty a tank. My relatively high mileage (50k miles) doesn't mean the same use of the battery than a bike that is used for commuting. He only has another C14 regularly for maintenance, and it has "only" 35k miles.
Still, he's testing the battery overnight and replacing it if necessary, as per my instructions.
I also ordered the Pirelli Angel's GT (A spec for the rear) which have just been approved by the TÜV in Germany. Except that I ordered the 55 for the rear  ;D I still have a few miles left on both front and rear, but in a week or two I'll be mounting the new ones and see if they are any different. They sure should, since the profile is much more round (less parabolic) than the ST's, so turn in and counter steering should be a whole different story.
Re: battery
« Reply #38 on: April 23, 2014, 07:39:41 AM »
Glad to hear you should be receiving you battery today, and thanks for the headsup on how long it took to get to you.
I had mine, in OHIO, 48 hours after ordering it.
It was delivered USPS Priority Mail.
I have no idea why they shipped UPS, unless you specified it in your order. And yes, they, (UPS), do take 7 full business days to deliver, counting from the day after pickup. Sounds about right, seeing as they don't pickup on Sundays.
The website still ships VIA USPS Priority Mail, I need a battery for another bike currently, and I just made a call to them, and asked.
It is as noted on the website.
Currently shipping an Adventure Power Battery Via USPS
" *BatteryStuff understands the importance of getting a replacement battery right away and usually ships all batteries the same day as ordered if received before 1:30pm (pacific), however USPS does not guarantee delivery times with priority mail. "
" Price includes FREE PRIORITY MAIL DELIVERY 48 STATES "
I also understand you were not in a hurry, my point was addressing the commentary about blaming the supplier about shipping matters they have no control over.
I'll let you know how long it takes to get my other battery.
thanks again for letting us know.
Offline Cold Streak
Re: battery
« Reply #39 on: April 23, 2014, 08:04:26 AM »
It's about time for a new battery for me.  When you order one online, what do you do with your old battery?  Throw it in the river?  :yikes:  Just kidding.  Do you have a recycling service nearby?  I buy my batteries at a local parts business and they take the old one for no charge.
