Author Topic: rear shock leak?  (Read 4086 times)
Offline flightrisk66
  • RIDE FOOL!
rear shock leak?
« on: March 16, 2014, 01:18:32 PM »
Hey me again,I pulled the c10 out for a ride ,started it up looked a few minutes later and saw some oil dripping from the bottom of the dog bones.The motor has no leaks as far as I can tell, could it be the shock?Thanks again for the excellent advice,Kev
Find friends and make new ones and ride together
Offline SteveJ.
Re: rear shock leak?
« Reply #1 on: March 16, 2014, 06:10:33 PM »
yes it could be. If the shock is leaking, throw it away. It is not repairable.
America's Seaplane City
Offline Rick Hall
  • Eruption
« Reply #2 on: March 16, 2014, 08:12:43 PM »
Possible.
Could also be the vent tube off the top of the transmission has popped off the air cleaner body. Engine blow by is collecting on the shock and dripping down. Look for crud on the forward end of the swingarm, and/or the aft end of the engine.
Like the guy from "Tropical Welch" sez, the shock is not reparable.
Rick
Offline SteveJ.
« Reply #3 on: March 16, 2014, 11:53:56 PM »
Going back a ways on the Tropical Welch, MN. Hiya Rick.
No longer looking forward to the end of winter down here in Flatistan.
  • RIDE FOOL!
« Reply #4 on: March 17, 2014, 08:30:30 AM »
Thanks again, thoroughly cleaned the dog bone area and took the bike for a ride. It was cold! will check the area again and post my findings.The motor only has 10K and looks like you could eat off of it. I guess time will tell.Thanks Kev.
Offline Summit670
« Reply #5 on: March 17, 2014, 08:11:26 PM »
The stock rear shock on my 87 was leaking oil, oh, 3 years ago.  I pulled the shock off and removed the rubber accordion boot.
What I saw were some minor scars/scratches in the shaft caused by something that must of been lodged in the seal.
I wiped the seals (insert a seal wiper between the shaft and seal and rotate it around the shaft/piston)
I then took some 600 grit wet/dry sandpaper and wet sanded the scratches till they were all but gone.  Shock hasn't leaked in 3 years.  Probably only 5000 miles on it though because I bought a newer bike and don't ride the 87 much these days.
I sanded in a cross hatch pattern. Would have probably followed up with some finer sandpaper but didn't have any on hand and the 600 seemed like it might be fine enough.
Arctic Cat M8 163 rules
Offline JoeRau
« Reply #6 on: March 18, 2014, 07:38:42 AM »
Who is from Welch?  I ride through there frequently.
2012 C14.  Black
COG member 10990
Offline SteveJ.
« Reply #7 on: March 18, 2014, 04:26:34 PM »
Me. I lived north of Highway 61 near the Church at 61 and the Welch Cut Off for about 18 years. Pretty much raised five kids there.
Offline JoeRau
« Reply #8 on: March 19, 2014, 05:44:28 AM »
OK.  My neighbor has family in Welch.  Some connection to the ice cream shop there.  A frequent stop for us when passing through.  That has to be one of my favorite areas in SE MN.
I am a Minnesota transplant... Came out of NW Wisconsin 12 years ago.  I miss the big lake and big woods, but not a lot of decent jobs up there.  Maybe someday we will go back.
Back to the original topic....
Last spring my rear C10 (2001) shock gave out.  The year before it had a slow air leak so installed a 12V airpump to easily fill it.  The leak got so bad that every 30 minutes I had to pump it back up.
I ended up ordering a Progressive 465 HD.  Best move I could have made.  At least until 2 months later when I sold the C10 & bought a new in the crate 2012 C14.
2012 C14.  Black
COG member 10990
Offline Mettler1
« Reply #9 on: March 19, 2014, 10:46:11 AM »
  +1 on the Progressive shock. Replaced my OEM with the Progressive over 10 yrs  and 60,000 miles ago. Dampening starting to get a little weak but still better than the original.
  • RIDE FOOL!
« Reply #10 on: March 20, 2014, 11:39:01 AM »
Thanks again all,I rode the bike and no oil yet.I will keep checking,Kev.
