Author Topic: Concours AUX/ Driving lights Picture request  (Read 8234 times)
Offline Flienlow
  • 2010 C-14 BLUE
« on: March 16, 2014, 12:12:39 PM »
I want to mount some driving lights under my mirrors. Looking for a pictures of what others have done. I am interested in seeing what you used, how you like it, and how you went about mounting them along with the switches.
Offline gildaguz
2009 Non ABS Concours Black
2004 Honda Shadow  Sabre 750
1979 Suzuki 185 all terrain
Offline JoeRau
Re: Concours AUX/ Driving lights Picture request
« Reply #2 on: March 18, 2014, 07:33:51 AM »
Last summer I was looking into the same thing, but I don't care for the ones hanging off the mirrors.  My wife pointed out they looked like earrings hanging there.  I tried a few ideas.
First was this.
It would work, but would have made a large shadow area with the light mounted that far back.
2nd attempt was
I used the factory body screws to hold the bracket in place.  This is what I will be installing this spring, but with a improved bracket painted to match.
2012 C14.  Black
COG member 10990
Offline Flienlow
  • 2010 C-14 BLUE
« Reply #3 on: March 18, 2014, 08:09:26 AM »
Thanks! Great Ideas.
Offline orangewingnut
« Reply #4 on: March 20, 2014, 12:51:18 PM »
here's my set up
Offline DkKnight
« Reply #5 on: March 22, 2014, 12:16:34 AM »
here's my set up
Any head on pics - I have my set of Piaa 1100 leds wtg to go on and am thinking about under mirror mount.
Paul in MD
Offline Ddfee
  • Be the person your dog thinks you are
« Reply #6 on: March 22, 2014, 03:55:51 PM »
Here's mine. Rigid Industries Dually 2's.
Dave
2011 C14
2003 Honda GL 1800
2000 Honda Blackbird
IBA Member
Offline MGvaleri
  • Country: it
« Reply #7 on: March 22, 2014, 11:26:59 PM »
Fari del GTR 1400 al BI-XENO,aggiunti faretti per eventuale guasto al BI-XENON.
MGvalerio 8)
Offline Flienlow
  • 2010 C-14 BLUE
« Reply #8 on: March 23, 2014, 09:09:14 PM »
MGvalerio 8)
We have a Winner!! that looks great! #Italians
Offline ljcorby
  • COG#: 9359
10 Kawi Concours 14 ABS
« Reply #10 on: March 24, 2014, 08:19:06 AM »
« Reply #11 on: March 25, 2014, 12:39:59 PM »
here you go
Bill
Offline C14lvr
« Reply #12 on: March 26, 2014, 09:37:49 PM »
Here's what I came up with.
Lights are 55w, comes with wiring kit and lighted switch... $20 Walmart.
Mounted on TRex crash bars.
Here's how well they work at night:
Huge difference!
Offline Smokeyzx
« Reply #13 on: March 31, 2014, 02:47:59 PM »
I want to install the mondomoto lights under the mirrors. OK, figured out how to take the mirror assembly off and it looks like it's held on by three bolts. There's a metal base that would block you from getting the nut in there. Does that come off to allow easier access? I'm guessing you can remove that once you have the whole assembly off.
Colorado
2013 Blue
Offline gildaguz
« Reply #14 on: March 31, 2014, 04:23:36 PM »
After you remove the mirror from the bike  you have to separate the upper part from the base removing those 3 screws  at the bottom, then you can take the metal base out of the plastic, then you can drill  in the middle of those 3 holes  with a drill bit about 4 mm or the required for tap threads for  a 6 mm bolt , after that you can make a hole on the bottom of the plastic cover to be able to run the wires inside , then you can put everything back  together and get a piece of pipe about 1/2 " diameter or less about 15 mm long to use it as spacer between the lamp and the mirror and use a 6mm  bolt 20 mm long to secure the lamp to the mirror base
I'm not a native English speaker so I hope you understand what I meant
Offline Smokeyzx
« Reply #15 on: April 01, 2014, 12:02:48 PM »
Thanks gildaguz, should have done it your way.
They are installed under the mirrors. woohoo!
There are three screws holding the metal bracket in there, two are under the rubber.
I drilled another hole to mount the lights closer to the fairing so I wouldn't have to cut off one of the three circular things sticking down. I had to cut off the longest anyway to get it past the nut... Didn't realize it until after I drilled. Not a big deal, they still look good. If I had to do it again I would use the existing hole.
Colorado
2013 Blue
