That's a small vise. If you are only going to get one, I would look for something in the 4" range at least. A larger one would give you the ability to perhaps press something together or apart, or at least be a good surface to pound on something. Assuming you don't have a workbench, you could mount the vise (with nuts and bolts) to a piece of sturdy wood, then clamp it down to whatever surface you can with a large C-clamp or two. I have one of these that I take to my rental properties when I need to work on them. Place thin cardboard or felt under it if you are worried about scratching the table you hook it to. You could even get fancy and use a mouse pad. If the table you are clamping to is not hardwood, I would use an oak shim under the clamp foot of the C-clamp so it won't damage anything (that much).
Or, you could get two and do this...
P.S. - Wooden paint stir sticks make great vise jaw and clamp shims. They're just about the perfect size when cut to length.
